Old 02-10-2020, 08:07 AM   #1
Korosion
Korosion's Avatar
Drives: 2016 2SS
Cam/Heads/Converter
Currently have long tubes, E85, Intake and tune. adding the below. Let me know what you guys think!
-Circle D 8L90 Pro Series 2600 stall converter (1A)
-Trans Fluid
-PRC CNC LT1 Heads
-TSP Cam (vvt2)
-Chromoly Pushrod Set
-LS7 Lifters and trays
-Gaskets and Seals
-VVT 0* Phaser Limiter
-Timing chain guide
-DOD block off plugs
-PRC dual spring kit with titanium retainers
-CHE trunnion Kit
-Delco head gasket set
-ARP Head stud kit (bolts are back ordered)
-GM crank bolt
-C5R Timing chain
-Synthetic Oil with Filter
-Coolant
Korosion is offline   Reply With Quote
Old 02-10-2020, 08:31 AM   #2
parbreak
Drives: 2017 50th Camaro SS
Looks like a great combo. Fairly low stall speed. Any reason why?
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
parbreak is offline   Reply With Quote
Old 02-10-2020, 08:34 AM   #3
Korosion
Korosion's Avatar
Drives: 2016 2SS
Thanks! and I wanted something that was great for everything, drag, street and autocross/HPDE
Old 02-10-2020, 09:41 AM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I would do at least a 3200 stall. The idle speed required for the cam is likely going to be pushing up against the brakes.
Old 02-10-2020, 09:44 AM   #5
gmcvt
gmcvt's Avatar
Drives: 2019 Camaro 1SS A10
This and doesn't the stall to torque ratio play into the picture here when talking about retaining driveability? As much or more so than the ultimate stall speed?
"Jesus said to them: I am the way, the truth and the life and no one comes to the Father except through me" John 14:6
2020 Mustang GT M6
2019 Camaro 1SS A10 E85/Pray tuned & ported IM/TB.**SOLD**
2018 Mustang GT A10 Kooks Lt's, E85 & Lund tune*SOLD*
2010 Camaro 2SS/RS M6 Silver- CAI, Bo-body, VRSP-2 cam, Kooks 1 7/8 Lt's w/cats, Magnaflow street CB(15089), QTP ovals, Elite can, Vengeance Racing tune. *SOLD*
gmcvt is offline   Reply With Quote
Old 02-10-2020, 09:49 AM   #6
Korosion
Korosion's Avatar
Drives: 2016 2SS
I honestly don't know, I am just going off of what my installer/tuner recommended for what I use the car for.
Old 02-10-2020, 03:00 PM   #7
oldman
Drives: SS 6 speed of course
Don't be me, get Johnson lifters and have them installed with proper preload.
My car with large cam idles at 900 RPM, FYI, the smaller TSP cam that I had idled at 850 RPM. Seems that DI and 11.5 CR can make-up for the loss of idle speed compression and vacuum. Frankly, I'm surprised.
I did the VVT limiter to 22 degrees? on my small TSP cam, most tuners don't use it anyway, I thought it would be interesting to retain it. Two things I notice:
1) this cam TSP says it is a perfect LT5 cam... interesting
2) https://www.motionraceworks.com/coll...t-w-roller-tip These look super.. must resist.
Old 02-10-2020, 05:19 PM   #8
KingLT1
KingLT1's Avatar
The main issue I see with the Circle D 1a is idle rpm. That VVT- 2 cam will likely want to idle around 800-850rpm and it will push against the brakes in gear with a converter as tight as the 1a. Stock coverter stall speed for the A8 is around 2200rpm if I remember correctly, so the 1a is slightly higher. Most NA builds go at least 3600rpm even with a stock cam, but imo a 3200 would work. Imho I think the better cam for your goals and setup would be the VVT-1.
sure does. I believe the converter OP is talking about is the 10.5" 265mm so it likely has a lower stall torque ratio for less slip down low(tighter) but doesn't hit as hard.
I would call Circle D and ask them their thoughts for sure. I had a 9.5" FTI 3600 soft hit(tighter version) in my 4th gen and it was great.. perfect for street/strip. I couldn't really go any smaller with the cam or it would of been up against the brakes with it's 850rpm idle. I ran it for a long time when it was stock cam and it still worked really well. jm2c.
Old 02-10-2020, 06:35 PM   #9
Korosion
Korosion's Avatar
Drives: 2016 2SS
Thanks for the recommendations, I will call circle D tomorrow and ask about the 3200 stall.
Old 02-11-2020, 10:51 AM   #10
70chevelleSS
70chevelleSS's Avatar
Drives: 2017 Camaro SS 1970 chevelle SS
-Trans Fluid
-PRC CNC LT1 Heads
-TSP Cam (vvt2)
-Gaskets and Seals
-Timing chain guide
-CHE trunnion Kit
-GM crank bolt
-C5R Timing chain
-Coolant
Strongly considering doing a similar build with parts from Pray. A little intimidated by the prospect of pulling the motor. That’s about the only thing holding me back.
I’ve pulled the motor on my chevelle multiple times but I’m a little intimidated by this lt1 with the vvt and stuff like that. A carbed 454 is much simpler
70chevelleSS is offline   Reply With Quote
Old 02-11-2020, 11:00 AM   #11
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
I’ve pull the motor on my chevelle multiple times but I’m a little intimidated by this lt1 with the vvt and stuff like that. A carbed 454 is much simpler
pulling the motor isn't that hard of a task to complete. Pray could spec out a more power driven cam though i would say, I did pretty much the same setup as OP but with the vvt3 cam and being a manual car.
If i could go back i would go with a bigger cam by pray with johnson racing lifters for added security as the ls7 do tend to fail on you.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 02-11-2020, 11:33 AM   #12
oldman
Old 02-11-2020, 12:09 PM   #13
Korosion
Korosion's Avatar
Drives: 2016 2SS
My installer is doing the cam swap without removing the engine.
Old 02-11-2020, 12:10 PM   #14
Korosion
Korosion's Avatar
Drives: 2016 2SS
How do you like the vvt3 cam? I am still debating one keeping with the vvt2 or going with the vvt3. Do you know what the differences would be in terms of sound, power and drivability?
