Old 02-06-2020, 09:27 AM   #1
Gen5&Beyond
Gen5&Beyond's Avatar
Drives: 2016 2ss Camaro
Spark Plug For Nitrous?
Looking for recommendations for spark plugs to use for a 200 to 300 shot of nitrous. Car is currently making 606/511 na. I’m currently using iridium plugs but have heard they may not be best for nitrous.
HBM 2016 2SS A8 NPP
427 Pray Head/Cam/Converter, Pray Ported Highram, 103mm TB, Pray Tuned, 3030 Drag Pack, Roark OTR CAI, TSP Headers, E85, UDP
Best times 1/4 n/a 9.23@146.96, 1/8 5.91@118
Gen5&Beyond is offline   Reply With Quote
Old 02-06-2020, 09:59 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
non projected tip 8 heat range.
Old 02-06-2020, 10:49 AM   #3
laynlo15
Drives: 2022 Lt1 A10
Those are big shots. I run the NGK LTR6IX which is one step colder for my Magnuson 2650 setup. I have a set of 7IXs also that I may run which is 2 steps colder. Gap is .028 on mine. Not sure if that helps you with the NOS setup or not.
Old 02-06-2020, 10:59 AM   #4
Gen5&Beyond
I’m currently running the 7IX for my na setup. I’ve heard that the iridium plugs don’t like the nitrous and was wondering if anyone’s tried a platinum plug with success?
HBM 2016 2SS A8 NPP
Old 02-06-2020, 11:22 AM   #5
KingLT1
KingLT1's Avatar
You shouldn't run the same heat range plug for boost or NA as you do Nitrous. A big shot like that requires a non projected tip and likely 3 heat ranges colder from stock. Plenty of info on LS1tech regarding correct plug, heat range, and gap that will apply to your setup. Something like a NGK br8ef or comparable Brisk.
Old 02-06-2020, 11:35 AM   #6
laynlo15
I had just ordered mine and switched the new ones back to the 7IX. Decided the 6IX just wasn't cold enough for 850 rwhp. Some guys are running the Brisk also and not the NGKs
Old 02-06-2020, 11:48 AM   #7
KingLT1
KingLT1's Avatar
Yes but it's not even all about heat range. We run projected tip plugs in boost and NA setups. If you run projected tip plugs on a Nitrous setup around 150 shot and above they can act like glow plugs and cause detonation.
Most don't run Iridium on a Nitrous car because they are expensive and get changed frequently. You have to run colder then boost or NA, plus the non projected tip tend to foul easier.
My opinion would be to run a 150 shot on a non projected tip 7 heat range. Above 200 you really should consider direct port instead of a plate for better distribution.
My best advice would be to call Dave or Brandon at Nitrous Outlet and get some professional opinions.
Old 02-06-2020, 12:21 PM   #8
laynlo15
I agree, I just noted that I switched mine to a 7 since I had posted otherwise. Good idea on the call Nitrous Express.
Old 02-06-2020, 12:25 PM   #9
IneedAZ
IneedAZ's Avatar
when i ran nitrous on my Gen5 i used Brisk Silver tips
Old 02-06-2020, 03:47 PM   #10
Paintslinger16
Two Lane Blacktop
Paintslinger16's Avatar
Drives: '18 Camaro 2SS
300 is huge...
Paintslinger16 is offline   Reply With Quote
Old 02-07-2020, 11:54 AM   #11
Gen5&Beyond
Thanks, I'll give Dave a call. The 150 shot was easy but stepping up seems to be a different ballgame all together. Just checking here to see if anyone had real world experience.
HBM 2016 2SS A8 NPP
Old 02-07-2020, 11:55 AM   #12
Gen5&Beyond
Originally Posted by Paintslinger16 View Post
300 is huge...
Yes it is!
HBM 2016 2SS A8 NPP
Old 02-07-2020, 03:02 PM   #13
KingLT1
KingLT1's Avatar
Yea not too many around here playing with big shots on the LT platform.
