Old 02-05-2020, 02:15 PM   #1
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
losing oil at WOT
So it seems I have a new issue or rather the first engine related issue. ive noticed twice now there was smoke coming from the under the hood after a few pulls to redline, first time there was some oil by the pcv, cleaned it up and continued to watch it. Its clean and fine under normal driving but now another full pull and i dumped smoke out on the highway and again some trails out the hood. This time i found a puddle in the belly pan and the whole front is wet. i pulled the manifold and believe the source to be from the sensor directly under the tb but i have no idea what it is. Its not bolted down and i cant find a diagram on the webs so does anyone know what this unplugged rectangular sensor is in the middle?
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
Joey Soul is offline   Reply With Quote
Old 02-05-2020, 02:23 PM   #2
oldman
Drives: SS 6 speed of course
I don't think I use that anymore, so it probably is at the oil flow valve to the DOD lifters.
Looks like that you gotta buy the whole valley cover (not saying this is the part, just an example)
https://www.amazon.com/Genuine-GM-12...5FDNDY0F82S1FB
Old 02-05-2020, 02:32 PM   #3
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
Cam position sensor?
ssmofo is offline   Reply With Quote
Old 02-05-2020, 02:36 PM   #4
Dixie ZL1
NOXQCES ZL1
Drives: 2017 Camaro ZL1
Looks to me like your oil pressure sensor is leaking.
Dixie ZL1 is offline   Reply With Quote
Old 02-05-2020, 02:43 PM   #5
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
hm yea youre right it looks like its all one piece. i wonder why its popping out though, its settled back in by the time i stop the car so i wonder if something is causing it to pop out for a second then settle back in
Old 02-05-2020, 02:45 PM   #6
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
nah thats the rounded sensor on the left, its still dry and so is the pcv. the oil was directly above this center sensor when looking at the bottom of the manifold.
i think that is directly infront of the cam, above the crank pully
Old 02-06-2020, 10:49 AM   #7
chaospiece
Drives: 2018 SS, 2016 GT
Also check the oil cooler.
chaospiece is offline   Reply With Quote
Old 02-06-2020, 12:55 PM   #8
easttxss
easttxss's Avatar
Drives: '16 2SS M6
Probably just a bad O-ring around the sensor.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB
'16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20)
'14 Fusion Titanium 2.0T
'83 Jeep Wagoneer
easttxss is offline   Reply With Quote
Old 02-06-2020, 05:17 PM   #9
DorkMissile
DorkMissile's Avatar
Drives: DZ
You are building up positive pressure in the crankcase - the PCV system on the LT1 really is pretty weak (when it comes to being able to handle a lot of air)
Unfortunately I see your crank pulley almost looks wet - could possibly be a blown front seal (eventually the pressure will push it out)
DorkMissile is offline   Reply With Quote
Old 02-06-2020, 05:53 PM   #10
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
yea i heard about those, currently its ok. The reason im led to believe its this sensors popping up is because i have no leak when driving normal or idling, only the last 2 times i did a full pull.. it seems this sensor pops up under pressure blows some oil into the manifold/ tb area then reseats its self. it cant be fully removed because its hard wired into the cover, couldnt even change the o ring if you wanted.
Old 02-08-2020, 11:08 AM   #11
Indy_62
Drives: 2017 2SS / 2003 S10 Crew Cab
The connector in the picture is for the afm solenoids in the valve lifter oil manifold. The connector is not serviceable; if oil is in fact leaking there the manifold would have to be replaced. There is so much oil in that area it is hard to tell where it is coming from. Adding dye to the engine oil and looking for the leak with a black light after a hard pull will help.
Never say never!
Indy_62 is offline   Reply With Quote
Old 02-09-2020, 08:30 AM   #12
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
Yea its only popping out at high rpm then it sits back flush. Really a strange thing i may do a compression test to check for damage. No reason a na car should have this much crankcase pressure
Old 02-09-2020, 09:32 AM   #13
95 imp
Dumb Ass Deluxe
A leak down test might be a better indicator since it seems to happen only under WOT. Sounds like a lot of blow by if it's pushing it out.
