![]() Drives: 2018 ZL1 Garnet Red Tintcoat A10 Join Date: Jan 2019
Race Ramps
Hope my fellow forum peeps could help me out. I have read many threads on the zl1 and which race ramps works best. Most comments are from 2018. I am gonna get a set just looking for some insight.
My main use will be for oil change and some minor adjustments. Do people prefer the XT version for 10" lift or the standard 8"? Which size are people using? 56 / 67 / 72. Definitely the 2 peice version. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Zigg, the 67 inch XT 2 piece ramps would probably be the ones to use with our ZL1s. They are designed for low clearance vehicles with 12 inch wide tires! Those are the ones I’m going to get from Summit Racing soon!
![]() Drives: Black 2019 ZL1 M6, Join Date: Sep 2019
I have the 67 inch 2 piece ramps and they work. the only thing that comes in contact is the little rubber pieces under the splitter. They just barley contact them when you place the ramps at the tires. As soon as you start to pull up and the tires come up on the ramps then they clear. You will be happy with the 67 inch 2 piece ramps. Using theses ramps i dont see how the shorter ones would not contact the actual splitter but others have said that it clears, but in my mind i just dont see how as there is an angle difference between the two.
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
![]() Drives: 2024 ZL1 M6 Join Date: Sep 2018
I have the 80 inch 2 piece version. I like that the front section can be flipped over and used to load on a trailer. And being a big boy, the 10 inch height is great for me.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp Kooks 2 inch LT's, Stainless Works Legend NPP THP Billet Valve Covers, Mighty Mouse Wild CC Signature Forged 20x10.5/20x11.5, BMR springs, BMR Cradle lockout, AAD Billet arms 2023 Vivid Orange ZL1 M6 - sold 2019 Riverside Blue ZL1 A10 - sold |
To fast is not enough
Drives: 2019 ZL1 Camaro & 2020 CT5-V Turbo Join Date: May 2019
Race Ramps RR-EX-14 14" Wide Extenders Xtender for RR-XT & RR-XT-2 (67'' Ramps) these is what I bought and works great
Is the 8" lift not enough? Seems like majority goes for the 10" and the 67 for the wider ramp. 56 and 67 XT have the same approach angle really depends if you want the extra 2" lift
#7 | |
![]() Drives: 2018 Zl1 Join Date: Jan 2010
This is exactly my experience and glad I didn't get the 56". No clue how that wouldnt scrape the front splitter and push the ramps. "Race Ramps RR-XT-2 Low Profile Ramp" |
#8 |
With the 67 Inch ramps you still need the extenders The Zl1 has that front lower dam that will scrape with just the ramps..
#9 |
That's what I was thinking because the 56 and 67 have the same approach angle. They have the 72in 2pcs with the gradual incline. But only 8" lift height and they are $340 vs the 67 XT is $363.
Would the 8" lift be enough? My first thought is yes. I am not a huge dude. But far from a small guy. I got about 8" from the floor to the top of chest. Then our ZL1 has about 5in from the floor to the frame. Total clearance would be about 13". Never thought I would be putting this much effort in ramps to change my oils |
#10 |
![]() Drives: Fastish Join Date: Jan 2019
At the price of race ramps, why not save more and get a quick jack?
I have to use the 72' one piece race ramp to get the ZLE to load into a trailer without scraping. but the working height with race ramps just isnt much. |
#11 |
I go with the ones I got and be done with it,a few dollars more is worth it then you don't have to keep saying I wish I got the better ones.
#12 |
the 72s will work confirmed without the extenders. they do barley and i mean barley contact those little rubber pieces under the splitter however. after the tire makes contact with the ramp they clear. I have used them since i got my ZL1...
Also the lift height is how high the tire from the bottom of it is lifted, not the center of the wheel is off the ground so even with the 8 inch lift you will still have plenty of room, it would be 8 inches plus whatever you have from the ground to the bottom of your car when its on the ground. so another 5 inches i am guessing.
#13 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
Me too!!!
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
#14 | |
It's only a very small piece of the vertical ridge thats on the front splitter. Not even enough to move the ramp and less then an 1/8" of an inch long part of it. Not even really an issue. |
