Old 02-03-2020, 12:11 PM   #1
parbreak
Drives: 2017 50th Camaro SS
Trans Removal
We will be removing the trans later this month to install Circle D converter. My son works at a speed shop and we've done all the installs so far, so have LOTS of confidence. We also have a lift.
Question: Any of you who have removed the trans, any particular issues we need to be aware of? He has every tool on earth, but any special extensions, etc., that help make it easier?
I've reviewed Lethal's video and understand the top bolts are a PITA.
Thanks
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
parbreak is offline   Reply With Quote
Old 02-03-2020, 12:32 PM   #2
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
i'd say its harder for us standard guys as the clutch likes to fight back.. I had to drop k member to be able to pull the trans out but no the top bolts actually weren't hard to get to but then again i did it with having the intake manifold off so we did those from the top of the engine bay then the rest of the bolts were from the bottom. their is quite a few bolts for the k member, hard to explain so use this thread and download the PDF https://www.camaro6.com/forums/showthread.php?t=500494
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 02-03-2020, 01:06 PM   #3
parbreak
Thanks for the link. We will be taking the intake off too for the LT4 stuff so I'll let him know to keep it off for the trans.
Old 03-01-2020, 10:08 AM   #4
parbreak
Update:
We had the trans lowered and new converter install in 3 hours. That included:
1) Exhaust removal
2) Drive shaft removal
3) Starter removal
4) Intake removal for top bolts (we're doing LT4 fuel also so it was coming off anyway)
5) Fill and reinstall new Circle D
We left it at that for the evening and had everything button up the next day in about 2 1/2 hours or less.
Couple things to note:
1) The headers (Kooks 1 7/8") did NOT need to be loosened or lowered for either starter removal or complete trans removal. In fact, we didn't even remove the O2 sensor on the passenger side.
2) It would be WELL worth removing the intake manifold to access the top bolts. For the few minutes it's takes, it's a no brainer.
3) We had a lift and trans jack etc., so that does make life easier.
4) This is all happening with other parts of the build going on. Custom lowside fuel system, Alky Control meth and E85, high side LT4 fuel.
Old 06-23-2024, 09:29 AM   #5
Waxenate
2019 2SS
Drives: 2019 SS
Sounds like you have the same set up as I do as far as exhaust. Thanks for posting the info.
When I had the engine built and supercharged I knew this day would come lol
2019 2SS
Bored and stroked to 416ci
Pro charger
Stage 2 intercooler
Crenshaw tune
Custom ported and polished heads
Kooks longtube headers
Borla 3” cat back S-Type
Biking 4 way adjustable coil overs
Multiple BMR upgrades
Waxenate is offline   Reply With Quote
