Old 01-31-2020, 07:10 PM   #1
Zboy136
Drives: Red Hot 17 1LE
Stock throttle body size
Anyone have any idea what size the stock tb is? Im going to be getting an msd intake soon, and trying to decide what route I want to take with the tb. Debating if i want to port the stocker or upgrade it.
Zboy136 is offline   Reply With Quote
Old 01-31-2020, 07:12 PM   #2
oldman
Drives: SS 6 speed of course
87 right, when I did mine only 103mm was available. But now you can get a 95mm too, I also have a Katch ported stocker which I think they call 90mm equivalent. Pray does a good port job IMO. I'd go 95mm now since it is vogue.
Old 01-31-2020, 07:18 PM   #3
Zboy136
Yes I was thinking the 95 because I can get it for 250 where as the 103 is 650.
Old 02-01-2020, 05:44 AM   #4
DorkMissile
DorkMissile's Avatar
Drives: DZ
Be aware that the stock LT5 throttle body will not fit on the stock LT1 manifold. WeaponX sells an adapter plate or Tick Perf sells a modified TB.
DorkMissile is offline   Reply With Quote
Old 02-01-2020, 06:05 AM   #5
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
If you do get an adapter plate, get it from soler performance imo. They are the only ones that smooths the transition from tb to manifold. I think it's free if you buy the tb from them, not positive though. If not, I have a weapon x adapter plate for sale hahaha.
Old 02-01-2020, 06:34 AM   #6
Zboy136
Going with the Msd intake, hopefully wont need the adapter plate.
Old 02-01-2020, 04:04 PM   #7
Mike@SolerPerformanceLLC
Mike@SolerPerformanceLLC's Avatar
Drives: 2015 Corvette Stingray
Hi, Zboy136.
Please, check our 95mm TB's they come with an Adapter Kit specifically designed for the MSD manifold, it will need it as the MSD screw hole pattern was made to receive the stock 87mm TB.
Not all TB's and Adapters are the same, nor they perform the same, pay attention to the little details and you'll see what I mean. Don't hesitate to call shall you have any questions.
Thanks,
Tiffany,
Soler Performance LLC,
support@solerengineering.com
www.solerengineering.com
(251) 468-9786
Mike@SolerPerformanceLLC is offline   Reply With Quote
Old 02-01-2020, 04:19 PM   #8
DannyC
Drives: 17 Camaro SS
I went with the Soler modified 95mm TB. It looks and works great.. They also throw in an adapter to fit the stock or a different adapter for the MSD.
Flow Tech axle back, Roto-Fab, Nick Williams 103, AEM Wide Band, Defrost vent pod, billet catch can, BBK long tube headers and NGK LTR6GP, #90198, one step colder, Magnuson 2650, Snow Performance water/methanol injection. (Also tune myself w/HPTuners)
DannyC is offline   Reply With Quote
Old 02-01-2020, 10:13 PM   #9
Zboy136
Originally Posted by Mike@SolerPerformanceLLC View Post
Hi, Zboy136.
Thanks,
Awesome Mike ty so much, I think I will be ordering the 95 from you.
