![]() Drives: ZL1 Mosaic Black Join Date: May 2016
Brake and Clutch Fluid - PSA for M6 ZL1
If your ZL1 or ZL1 1LE M6 is shuddering while shifting into 1st and reverse ONLY when the engine is warmed up, you may have a low clutch and brake fluid level.
The good engineers at GM still decided to combine the brake and clutch fluid together just like the 5th gen. To remedy this issue, simply purchase a bottle of AC Delco DOT 3 Brake and Clutch fluid and CAREFULLY add to the fill line reservoir. If your brake fluid appears dark brown, then it will need to be replaced due to use and moisture contamination. Symptoms: In stop and go traffic and dead stop right/left red light turns, the vehicle forward motion requires more throttle than usual to NOT shudder. Brake and Clutch fluid: AC Delco Dot 3 Brake and Clutch Fluid #10-4110 For the track rats, a DOT 4 of your choice is advisable; however, you may want to change it out once you hit the street. |
![]() Drives: 2019 ZL1 1LE Join Date: Dec 2019
Curious... why do you think changing back to Dot 3 for street use would be better ???
Track rat, Bill 😇 |
#3 | |
, Dot 4 does not handle moisture very well. Even though the boiling point is higher providing great performance, the ability to maintain its characteristics for longevity are lower in comparison to Dot 3. |
![]() Drives: 2018 ZL1 1LE Join Date: May 2019
The reason DOT 3 is factory fill, is that its less hygroscopic than DOT 4, its also typically cheaper. I run DOT 4 and flush every 6-12 months depending on track usage, and bleed constantly. I wont be going back to DOT 3 as it doesn't perform as well in any condition. With proper maintenance there should be no issues.
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial Will buy your GoodYear Supercar 3R Take offs! |
![]() Drives: 18 ZL1 1LE Join Date: Apr 2013
I'm not sure why GM decides to have the clutch and brakes share the same reservoir. I haven't looked into it for my 6th gen, but on my 5th gen I purchased a second smaller reservoir for the clutch.
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
From my Mustang days, someone did a fairly well done investigation into clutch+brake reservoir combinations. One thing that was found was that, through use of the hydraulic slave cylinder/throw-out bearing, clutch material and slave cylinder seal material would migrate into the the fluid slowly and contaminate it. That among typical moisture absorption and the fact that the fluid doesn't circulate all that well can start to effect proper clutch actuation to a small degree. There were all kinds of science projects going on to help deal with the crappy performance/track shifting characteristics of the MT-82. Divorcing the clutch and brake reservoirs lead to more long term consistency in clutch actuation and no cross contamination between clutch and brake. Something worthwhile for the MT-82/Mustang, but maybe not as worthwhile to the Camaro since the Tremec is designed a hell of a lot better for performance/track use and the GM clutch design strategy has a better eye for performance than Ford has had. I would just use a vacuum pump to change the fluid in the clutch circuit from time to time. |
#7 |
![]() Drives: 2017 Camaro ZL1 M6 - Black Join Date: May 2015
Krowser - I had this issue and a flush seems to have worked for me. Thanks for the notice!
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
Does anything need to be done to the clutch when doing a brake fluid flush?
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
#9 |
No.
#10 |
TEXIT
Drives: 2019 ZL1 M6 Join Date: Aug 2018
I just got a motive pressure bleeder and plan to bleed the brakes and evacuate the clutch side. Then pump the clutch pedal a billion times to get fresh fluid in there.
Anyone know how much fluid it will take? 1 or 2 quarts for the entire job? |
#11 | |
How are you evacuating the clutch side? I thought it was all in the same reservoir ??
#12 |
Who Needs to KNOW?
Suck the fluid out of the reservoir, refill w NEW fluid and bleed. Dont let it run dry.
Stock fluid is very brown, even when new. Motul 600 RFB was not much lighter in color. I miss the ATE super blue. You knew when you reached new fluid, esp if you alternated fluids types.
#13 | |
TEXIT
I plan on doing the clutch and brakes at the same time so I'll evacuate them both. |
#14 |
![]() Drives: 2016 Chevrolet Camaro 2SS Vert Join Date: Apr 2023
I’m having this similar problem on my SS when I reach the bite point of my clutch in first or reverse from a dead stop and I give a little bit of gas. Whole car starts shuddering/shaking. Only happens when the car is warm and has been driven for a while. Is this similar to what everyone else was dealing with? I bled my fluid once, it seems like it might’ve gotten better/not as aggressive shuddering as before, or maybe it’s my imagination. I’m going to try doing a full bleed again and see how it is.
