Old 01-27-2020, 08:24 AM   #1
cam765
Drives: 2019 SS
2019 Camaro SS - K2 fuel pump relay
I am doing some work on a 2019 Camaro 2SS, and it won't start (no crank, no clicking). I looked through the rear compartment fuse box, and I was surprised to see K2 (fuel pump relay) not present. Even more interestingly, it doesn't even look like it should have this relay as I cannot see wiring or connection terminals where the relay plugs in.
Can someone confirm on their car or comment if this relay should or should not be there? If it should be there, I have a lot of questions why it would have been removed
cam765 is offline   Reply With Quote
Old 01-27-2020, 09:02 AM   #2
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
What kind of WORK? Did you disconnect the battery?
ssmofo is offline   Reply With Quote
Old 01-27-2020, 09:06 AM   #3
cam765
Drives: 2019 SS
Doing some front end work following an accident. The battery has been disconnected and reconnected... why do you ask?
Old 01-20-2024, 11:30 PM   #4
Jaeblvck
Drives: Chevy Camaro SS
did you end up finding anything? I'm looking for it as well or somewhere to connect to it
Jaeblvck is offline   Reply With Quote
Old 01-25-2024, 11:21 AM   #5
ctrlz
Some of the relays are integral to the fuse box and not separately serviceable. I believe both the front and rear main boxes include these types of relays.
