Old 01-26-2020, 10:06 AM   #1
byz250f
Drives: ZLE
anyone removed factory wrap on ZL1 1LE hood?
Curious if anyone has removed the factory wrap on a ZL1 1le hood. Curious if the hood is matching factory paint. Not a fan of the hood wrap.
byz250f is offline   Reply With Quote
Old 01-26-2020, 10:27 AM   #2
scantone
Drives: 18 Z1E - 18 Raptor - 17 Jeep SRT
Mines off no issues with paint once you polish it up
scantone is offline   Reply With Quote
Old 01-26-2020, 03:38 PM   #3
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
Hood is the color of the car under the wrap
nancygrl is offline   Reply With Quote
Old 01-26-2020, 04:26 PM   #4
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
That was peeled off within a hour of taking delivery, looks much better IMHO, black car here.
Warrior102 is offline   Reply With Quote
Old 01-26-2020, 08:27 PM   #5
byz250f
Drives: ZLE
perfect thats what I was hoping to hear...not a fan of the finish, looks cheap and shows every mark on it.
Old 01-26-2020, 11:45 PM   #6
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
I agree... One of the reasons I didn't buy a 2SS 1LE was the black wrapped hood... Looked like primer... That and I didn't want the M6 as this car will eventually become my daily driver in SoCal traffic...
If I could have gotten the 1LE without all the black and an A10, I would have happily spent the $7k... I LOVE the 1LE wheels/tires...
Old 01-27-2020, 12:15 AM   #7
waterman
waterman's Avatar
Drives: Grandad's C2 L89
There are some really nice matte black Vwrap products that I have had impressive results with. Chemical Guys Meticulous Matte Detailer and Spray Sealant works really well. A quick spray and micro fiber wipe after wash makes it look like new. The wife's hair dryer works really well to seat the edges where it ends to peel.
I digress, I have a buddy down the block who removed the Vwrap from his 2017 SS 1LE, hood was paint matched.
2018 ZL1 1LE sw/PDR
Old 02-02-2020, 02:02 PM   #8
Vader1LE
Drives: 2018 SS 1LE
Warrior102 do you have some pics of your car? I have the same one and I can’t tell if I like the wrap or not. Tossing around the idea of taking it off.
Vader1LE is offline   Reply With Quote
Old 02-02-2020, 10:38 PM   #9
1hprush
2018 ZL1 1LE
1hprush's Avatar
Drives: 2018 ZL1 1LE
Has anyone that has removed the matte vinyl hood wrap, had any issues with it pulling off the paint? Did you use heat to remove it? Thx!
1hprush is offline   Reply With Quote
Old 02-03-2020, 03:43 AM   #10
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
[IMG]
i need to search by image[/IMG]
Old 02-03-2020, 05:24 PM   #11
442DMND
Drives: 2017 SS/1LE
1LEs have sunroof available now?
2017 SS/1LE Hyper Blue Metallic, PDR, Illuminated Bowtie, GM Dark Tails, Diode Dynamics Sidemarkers
442DMND is offline   Reply With Quote
Old 02-03-2020, 08:02 PM   #12
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
I removed mine on a hot sunny day in August, peeled right off. Open the hood, pull the plastic push pins holding the liner, remove the 8 - 10mm (don't recall) nuts holding the vents, grab an edge and start peeling. This time of year a bit of heat would probably be needed, a hair dryer would probably suffice. The hood was pretty free of adhesive, there was a bit around the edges easy removed with alcohol.
If you change your mind any car wrap shop can replace it for short money, if I were to ever replace it (not likely) I would go with a satin rather than the flat black.
Old 02-03-2020, 09:09 PM   #13
1hprush
2018 ZL1 1LE
1hprush's Avatar
Thanks, I like the satin version too and may end up going that route.
Old 02-04-2020, 10:21 AM   #14
Matos1LE
Drives: SS 1LE
Man, this is one friendly forum! We keep happily answering the same question that has been asked in several other threads. Other forums I have used always have people make snarky remarks demanding the OP try searching. Driving a nice car is clearly helping our collective moods
Matos1LE is offline   Reply With Quote
