![]() Drives: 2019 2SS 1LE Join Date: Jan 2020
Jumpy, hoppy suspension or tires? 30-40mph
Hi guys,
I am in love with my brand new 2019 2SS 1LE that I purchased recently. However I would like to know if it is the characteristics of this car to have a very sensitive suspension. I feel like if the car was always hopping or jumping up and down, specially when cruising between 30-40mph. You can feel it in all driver modes. It is like a constant hop, kind of like a flat spot on a tire but except that at highway speeds I dont feel anything, it is very smooth. so i dont know what it is or if it is normal, any suggestions or feedback appreciated. thank you!!! |
![]() ![]() ![]() ![]() ![]() Drives: 2023 ZLE Join Date: Jun 2009
Not sure what the roads are like that you are driving on but the suspension on the 1LE is stiff. You can literally feel every crack and expansion joint in the road. It’s much stiffer that a standard SS.
#3 | |
I took the car to another shop (Discount Tires) and had them re-balance the rears and all was good.
thanks for the info, is not a vibration is like a synchronous jump, like the car hops like a bunny.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
Maybe a dumb question, but have you checked to make sure that the shipping blocks have been removed from the springs?
The 1LE isn't actually all that highly sprung, if anything it has rather soft springs for a track version car, and it can do this because of the MRC shocks. Now it does have stiff sway bars, but sway bars wouldn't cause that, the sway bars do transfer some "cross talk" , but that is a different sensation. Mine it smooth, but it is not plush, nor is it meant to be. The MRC calibrations are designed for the track. If you are getting constant vertical motions though, then something doesn't seem right because that is NOT one of the characteristic of this car, unless it is the roads.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
#6 | |
![]() ![]() Drives: 2002 z28, 2023 Zl1 Join Date: Sep 2012
#7 | |
Drives: 19 Camaro SS 1LE, 03 Ford Lightning Join Date: Nov 2019
These orange things on the springs don't belong there for anything other than GM transporting the car to the dealership. If they were left on/in the front springs then jack the front of the car up and pull the out of the springs. They just lift the frontend a little to give the car a little extra ground clearance. ![]() Even though I will say that my car with the lifting blocks rode surprisingly well. But it's still a good starting point to try and fix your issue. In my experience if the road produces a constant buzz or rough ride like it hasn't been repaved since the 1970's then the magnaride does little to mute that in this car, but it's ability to soak up and absorb sudden, harsh, jarring impacts is very admirable and/or impressive. |
#8 | |
![]() Drives: 23 Zl1 Join Date: Apr 2019
Man that's the way to describe the suspension right there |
#9 |
![]() Drives: 2019 1LE Join Date: Nov 2019
My 19 1le is silky smooth.
"That my friend.. is the sweet succulent sound of the car preparing to ignite the wonderfully tasty nectar your V8 needs to send the screaming bald eagles furiously from the 4 pipes out of the rear of your vehicle"
#10 |
thank you all, i dont have those blocks on the springs. I dont know i think sometimes i am being OCD because at highways speed is very smooth. I am lost at this point. Maybe bad wheel balancing? Where are the counterweights used for wheel balancing on these wheels? i cant find any
#11 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
#12 |
![]() Drives: 2019 2SS 1LE Join Date: Aug 2019
Behavior is not normal in my car. Perfectly smooth with the OE wheels & tires on.
The only thing I felt is the rear end hop on hitting a big bump with the fresh bushings & 60 pound wheel/tire combo. I suspect that's settled in a bit now. I do notice that I can notice road imperfections quite easily with this car. A section of highway has a slightly undulating surface near me & I never really noticed it until I drove this car. That's saying something, considering my last car was a Fiesta ST and they're not exactly known for comfortable suspension. |
#13 |
![]() Drives: 2018 Camaro SS 1LE Join Date: Sep 2018
Tramlining?
#14 |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
