Old 01-25-2020, 12:04 PM   #1
Jfmoore79
Jfmoore79's Avatar
Drives: 2016 Garnet Red 2SS A8
315/30/20 on ZL1 Wheel
I have read some say running at 315/30 is possible and others say it tore the wheel liner up too bad. Can anyone confirm they have done it successfully? What wheel, offset, and spacer did you run?
2016 Camaro 2SS - Auto - MRR 017 - Garnet Red
P1X w/ Stage II IC, LT4 Fuel System, JMS Voltage Booster, MMS Catch Can, JRE Off Road Pipes, JRE Tune
Jfmoore79 is offline   Reply With Quote
Old 01-29-2020, 08:28 PM   #2
Markoz28
Drives: 18 ZL1 nightfall grey A10
You run that size on the OE wheels but I would move the wire harness and massage the inner liner on the drivers side. Very easy to do and till only take about 1.5 hours and that with taking the wheel off, the liner off, moving the line with zip ties, massaging the hump in the liner with heat gun and a roller, putting the liner back on, and then the wheel. Cake!
Markoz28 is offline   Reply With Quote
Old 01-29-2020, 08:38 PM   #3
Jfmoore79
Jfmoore79's Avatar
Thanks! I’m going to work on the harness and liner in the next few days before I order any tires.
Old 01-29-2020, 08:54 PM   #4
Markoz28
For reference I have a 325/30/30 but on a custom wheel and off set. Fits great!
Old 01-29-2020, 08:55 PM   #5
Evolvedx27
Evolvedx27's Avatar
Drives: 2017 ZL1
Super easy to do. 20 min.
Evolvedx27 is offline   Reply With Quote
Old 02-27-2020, 06:03 PM   #6
SgtRick
Drives: 1968 Camaro and 2019 ZL1
We did it in about 30 mintues. You can undo the front half of the wheel liner and just fold it back and then move the wire harness and zip tie to the brake line. Put it back, used a heat gun to smooth the empty hump in the liner and done.
SgtRick is offline   Reply With Quote
Old 04-15-2020, 09:37 PM   #7
Bain
Drives: 2019 Shadow Gray Metallic ZL1
About to put 315/30’s on my ZL1 Friday. I will let you know how it goes.
Bain is offline   Reply With Quote
Old 04-16-2020, 06:51 PM   #8
Markoz28
Post pics when done.
Old 04-18-2020, 06:31 PM   #9
Bain
They are on. Michelin Pilot Sport 4S
295/30/20 front
315/30/20 rear
Old 04-28-2020, 03:30 PM   #10
pizokk1
pizokk1's Avatar
Drives: -17 hyper blue 1ss black rims
Can you put a side view picture?
pizokk1 is offline   Reply With Quote
Old 04-28-2020, 11:39 PM   #11
Bain
Here you go.
Old 04-28-2020, 11:42 PM   #12
Bain
What is up with my pictures posting sideways?
Old 05-02-2020, 11:02 AM   #13
Bain
Can anyone fix my pictures?
Old 05-03-2020, 10:14 AM   #14
OVRKLL
Drives: 2017 1SS 1LE...makes me go YeeeHaw!
Car looks great...even sideways!
Any rubbing issues with the front 295s?
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late!
OVRKLL is offline   Reply With Quote
