Old 01-24-2020, 01:53 AM   #1
Gary H
Drives: Camaro ZL1
Definitive belt size for 9.17" lower?
Hi all
Need a bit of help!
Car goes into the Shop on Monday and I've just received my Super Damper and 15% OD Pulley ( 916227).
The belt I received as part of the package is a K080842HD
The research I've done says most people use the 845HD or even the 845RPM.
Has anyone used the 842 or will it be too tight?
If I go 845, is it worth getting the RPM variant?
Many thanks and any help appreciated if I need to order something today and express ship across the Pond!
Made in the USA. Refined in Great Britain - insta: zl1uk
Velossa intake, Rotofab, Mamo TB, Custom ported NX Lid & Jokerz Full tilt ported LT4 charger, 3 port CoolingMist Meth injection - ATI 15% lower pulley, E2X CC, TSP ceramic coated longtubes, de-cat and Borla 60608 to NPP box, JRE tune, BMR rear control & trailing arms, lock-out kit, lowering springs and front strut brace, Custom carbon trim interior, Xpel ultimate front PPF and Prestige window tint with Chameleon Windscreen tint...ever evolving...
Gary H is offline   Reply With Quote
Old 01-24-2020, 06:24 AM   #2
TMS
TMS's Avatar
Drives: 2018 ZL1 1LE - HBM, PDR
I would recommend the 845HD belt for the 9.17 lower.
You might read through this post regarding my experience with the 842 and the 845 as well as the RPM vs the HD belts. Analysis is not scientific but the results speak for themselves.
You might be OK with the 842 in the HD variant. And you might be OK with the RPM in the 845 variant but not the 842RPM variant.
https://www.camaro6.com/forums/showthread.php?t=523261
JRE Tuned (HPTuners) | 15% OD (9.17" crank pulley) | TVS2300 Maggie Heartbeat Supercharger - 14 psi | E-50 (DSX Flex Fuel kit) | JMS FuelMax Fuel Pump Booster | LPE Big Bore High Volume DI fuel pump | LPE High Flow DI fuel injectors | LT5 95mm TB | RotoFab CAI | AEM X-Series OBD2 wide band gauge | Elite Engineering E2-X catch can | Borla S-type NPP Cat-Back 3" exhaust | Forgeline GTD1 5-lug Satin Graphite | SunTek wrap | C-Quartz Finest Reserve ceramic coated
TMS is offline   Reply With Quote
Old 01-24-2020, 06:49 AM   #3
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
Don’t use the rpm belt. I broke one and most people have went back to the hd belt.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp
Kooks 2 inch LT's, Stainless Works Legend NPP
THP Billet Valve Covers, Mighty Mouse Wild CC
Signature Forged 20x10.5/20x11.5, BMR springs,
BMR Cradle lockout, AAD Billet arms
2023 Vivid Orange ZL1 M6 - sold
2019 Riverside Blue ZL1 A10 - sold
XXX ZL1 is offline   Reply With Quote
Old 01-24-2020, 07:07 AM   #4
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
I'd stick with the Gates HD Micro-V Belts. I've got the same balancer but maggy 2300 on the other end, no issues.
When you get it on look where you tensioner lands. Make sure it won't bottom out to the left or is so far right you don't have enough tension. Here is my K080859HD with 9.17" and 3" upper on my 2300.
This is a little left of center and is prior to first start so it will likely land in the center.
Old 01-24-2020, 08:15 AM   #5
Gary H
Drives: Camaro ZL1
Appreciate the response and thank you for that very informative post.
Old 01-24-2020, 01:22 PM   #6
Hyper_Zl1
Drives: 2018 Zl1
845HD on mine with a 9.17 lower
Hyper_Zl1 is offline   Reply With Quote
