Old 01-23-2020, 07:51 AM   #1
MrcamaroZ28
MrcamaroZ28's Avatar
Drives: 2015 Black Z28
Best alcohol injection
What is the Best alcohol injection? I know I will need a tune to get the maximum performance but is it necessary to have it tuned? And how much HP can I gain with no tune verse with a tune. (2018 camaro SS 6speed, D1 Procharger)
MrcamaroZ28 is offline   Reply With Quote
Old 01-23-2020, 08:23 AM   #2
Umbriel
Drives: 2016 Camaro SS
I used Alky Control on my 4th gen, not planning on running meth on this car.
Umbriel is offline   Reply With Quote
Old 01-23-2020, 09:15 AM   #3
laynlo15
Drives: 2022 Lt1 A10
I have the AEM with 1-1000cc nozzle but have run 2 nozzles in the past. Yes you need a tune.
Old 01-23-2020, 09:28 AM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Yep you need a tune. It will run rich if you don't. Meth has to be treated like additional fueling for it to work or your engine runs rich. DI motors don't like to run rich...so it's not like port injected stuff where you could use it for cooling only and run a little richer. The fuel system will need leaned out some. There is a fine line there...For a rough example, I know some will tune for .85 lambda on fuel system, then spray meth to get it back into the .82 range. This way if the meth fails it goes a little lean but doesn't nuke the engine.
Old 01-23-2020, 09:33 AM   #5
Choda
Drives: Turbo 6.2
I have been using alky control with devils own screw in nozzles on my last two turbo setups. Never had an issue. The amount of power it makes is not clear to me. I never added meth and only meth. My tuner adjusts the whole tune when using meth and I have always added boost when adding meth.
2016 Twin Turbo Camaro SS - 968hp/970tq 8.9@153
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 01-23-2020, 09:44 AM   #6
shinysun
Can anyone recommand the location of nozzles for the spraying equally to each cylinders? I am planning to put 4~6 nozzles for it.
shinysun is offline   Reply With Quote
Old 01-23-2020, 10:57 AM   #7
laynlo15
Devilsown has a kit you can use and a couple guys with 2650 Maggies are spraying into the intercoolers thru the lid instead of the elbow. Mine are still in the elbow but I'm changing mine also to the lid. Gen6mike is using the same pump that comes with the Meth kits and it looks cool running into the lid.
Old 01-23-2020, 04:58 PM   #8
shinysun
PM sent.
