Old 01-23-2020, 01:06 AM   #1
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
Magnuson 2300 and Bolton 700+ rwhp
Finally put the car on the dyno to get a baseline. I’m running a Maggy 2300, 3.15 upper pulley (stock 80mm is 3.2), 2 inch ARH full system, 103 inlet, and rotofab big gulp. Setup made 12 lbs on the dyno. Car made 703 rwhp and 709 rwtq on 93 and NO meth. Fueling looks good here and I will work on timing tables on the street/track. Car will take another 3 degrees easy, but with the fuel limitation of the stock cam I want to inch timing in and watch fuel pressure. Air/fuel was half point rich also, but I’ll clean that up when I get on the street and can watch pressure.
Air temp and MAT temps is where this thing shines. Temps are much more manageable over stock blower. Very minor climb during the dyno pull and recovers well, something the stock blower doesn’t do well on the dyno.
I think the car will make 740 rwhp range with fueling and timing cleaned up. As long as stock fuel system allows it. Lol. With the pulley it’s running I’m not even scratching the surface of what this blower is capable of. Plenty of room to grow!
UPDATE- Low side starting falling pressure past 700. Commands 73 and fell to 68 psi. Adding JMS voltage booster I got from Ted Jannetty to take care of low side issue. Then back to tweaking.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp
Kooks 2 inch LT's, Stainless Works Legend NPP
THP Billet Valve Covers, Mighty Mouse Wild CC
Signature Forged 20x10.5/20x11.5, BMR springs,
BMR Cradle lockout, AAD Billet arms
2023 Vivid Orange ZL1 M6 - sold
2019 Riverside Blue ZL1 A10 - sold
XXX ZL1 is offline   Reply With Quote
Old 01-23-2020, 06:58 AM   #2
Markoz28
Drives: 18 ZL1 nightfall grey A10
Over 700 whp is fantastic. I think it’s a great balance between power and usability. I was going to spend the cash and go with a 2650 and cam to push to 850whp. Would have been pretty easy too. After some thinking, how much power can I put down? So we opted to go for anything over 700. I’m going the ported SC cam route. I know heat soak is an issue but I don’t mind waiting 30-45min between 1/4 mile passes.
Markoz28 is offline   Reply With Quote
Old 01-23-2020, 07:03 AM   #3
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
With a cam you will not have to get aggressive with pulley to make the power as the cam will do the work. These cars are a lot of fun in these power range. Lol
Old 01-23-2020, 07:26 AM   #4
laynlo15
Drives: 2022 Lt1 A10
I think you'll be really close to that. Those are good baseline numbers and anything over 700 makes a dam fast ride.
Old 01-23-2020, 08:00 AM   #5
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
Are you tuning it yourself?
Mike.
ssmofo is offline   Reply With Quote
Old 01-23-2020, 09:29 AM   #6
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
Mike.
I am. I’ve been tuning for 19 years.
Old 01-23-2020, 09:32 AM   #7
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
Thanks again for the help with the blower! Your buddy was great to deal with!
Old 01-23-2020, 09:37 AM   #8
staples87
Drives: 2017 Camaro ZL1
I'm extremely impressed with your results so far! Are you running any type of low end fuel voltage booster, or did you just bolt on the 2300, headers, rotofab and sent it?
'17 Camaro ZL1 M6
staples87 is offline   Reply With Quote
Old 01-23-2020, 11:54 AM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
SWEET!!! I was considering ported OEM and such but that recovery and soak were things that kept concerning me. It's too bad there isn't a kit I can run here (except for the big brother 2650 )
'20 ZL1 Black "Fury"
radz28 is online now   Reply With Quote
Old 01-23-2020, 01:24 PM   #10
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
Stock low side. An aux kit or voltage booster wouldn’t hurt though. So far it’s good, but I’m on the line for sure.
Old 01-23-2020, 02:43 PM   #11
2ltrgsr
AXLERODZL1
2ltrgsr's Avatar
Drives: 2019 Riverside blue ZL1 Camaro
She's a beast!!
'19 ZL1 A10 Riverside Blue PDR/Nav/Sunroof
Kong ported blower/snout
Roto-Fab Big gulp
103 TB
Lingenfelter Lower Pulley(9.17)
1 7/8 ARH headers and Exhaust
Meth injection(single nozzle)
733whp/788tq
2ltrgsr is offline   Reply With Quote
Old 01-23-2020, 03:22 PM   #12
staples87
Well hopefully it will lessen the duty cycle when you pull some fuel out. What is your target air/fuel? I feel that most people tune them 11.2-11.8 for optimum safety.
'17 Camaro ZL1 M6
Old 01-23-2020, 04:25 PM   #13
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
I stay around 11.8 or so. The direct inj stuff likes being little leaner. Some are doing 12.2-12.5 and having luck, I’m just not that guy. Lol
Old 01-25-2020, 09:50 AM   #14
Revalot
Drives: ZL1/1LE parts added
Location: Somewhere around Texas pines tress and smooth asphalt
I have Roto fab dry, borla 2nd cats removed catback Atak mufflers. If I added a cam(Mild) later no headers, would the high and low injection be fine ? The finishing touch would be the lope.
Revalot is offline   Reply With Quote
