Old 01-20-2020, 07:58 PM   #1
ZL1_2017
ZL1_2017's Avatar
Drives: 2017 TT ZL1 TH400
Cordes Front Bumper Ice Tank and Cordes Breather tank
Looking for install threads on routing and how to for the two items in description. I am trying to accomplish this myself and I feel I'm mechanically inclined so I just need a little insight on routing the lines 2 and from. If you have step by step would be great or just some pictures would also help. Thanks..
2017 TT Camaro ZL1 / TH400 / LME 416 / LME CID HEADS / Huron TT 68/71 106 / Crawford Port Injection / Holley EFI / AEROSPACE Components fronts and rears / 15" Weld Beadlocks / Torqbyte Methanol Kit / Prometh Trunk Tank / Plazmaman Intake
ZL1_2017 is offline   Reply With Quote
Old 01-20-2020, 09:12 PM   #2
laynlo15
Drives: 2022 Lt1 A10
I'd rather have the tank in the trunk.
Old 01-20-2020, 10:09 PM   #3
ZL1_2017
ZL1_2017's Avatar
Lol.. yeah I agree. I'm using it for more volume not for ICE. I been talking your fast guy over here in California Mike and he has stated the same. But for now any help. I found the way to run the passenger side fitting to the SC but concerned on running the driver side to the pump. Help a member out. Thanks
Old 01-21-2020, 08:58 AM   #4
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Can U route the hoses up from the bottom going through the deflectors on the sides of the radiator/exchanger? It may take you sourcing some barbed Heater hose connectors and Gate hose along with pre-made elbows to make the bends. Orilley's allowed me to go in the back and they had 1000s of hoses in 5/8 and 3/4 elbows, S bends, 5/8 to 3/4 hose tapered.. added a pic of the deflectors like the aftermarket SC companies have you go through to add and exchanger.
Old 01-21-2020, 11:28 AM   #5
ZL1_2017
ZL1_2017's Avatar
EDFHOBBIES thank you for the illustration. I'll go check it out. I'm sure there is a way with the supplied hose and fittings. They sent me a 90 degree for the passenger side but on the driver side I recieved an straight fitting. But nonetheless I appreciate your help and thanks again. I'll email Joe at Cordes and see if they can send me install pictures.
Old 01-21-2020, 12:06 PM   #6
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
No problem..
