Old 01-18-2020, 05:35 PM   #1
Josedlc98
Drives: 6th gen camaro ss
tsp headers & mbrp catback exhaust
do the tsp headers bolt up to mbrp catback with out any modifications
Josedlc98 is offline   Reply With Quote
Old 01-25-2020, 04:21 PM   #2
Juiced1
Drives: 2012 2SS CAMARO 45th
You will need to weld. Any of the catbacks or xpipes that delete the rear cats will need to be welded to connection pipes of the headers. Without a true connection point its difficult. We usually recommend to get a set of headers with a full Xpipe and then get a axleback if you still need more volume.
Juiced1 is offline   Reply With Quote
Old 01-28-2020, 04:05 PM   #3
Jarredb
Drives: 2018 camaro ss
What about the AWE touring catback exhaust?? Looking to get headers also but not sure what modifications if any would need to be done.
Jarredb is offline   Reply With Quote
Old 01-30-2020, 09:01 AM   #4
Juiced1
Any catback that deletes the rear cats will overlap with long tubes and require welding.
Old 02-29-2020, 11:52 PM   #5
BruceWayne1LE
BruceWayne1LE's Avatar
Drives: 2018 Camaro SS 1LE M6
Mbrp doesn’t delete the cats at all.
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ
BruceWayne1LE is offline   Reply With Quote
Old 03-01-2020, 10:31 PM   #6
Juiced1
With the MBRP catback you would be good with any headers/connection pipes. Should sound amazing. If you still need the parts hit us up.
