![]() Drives: Camaro ZL1 Join Date: Jan 2018
Kooks 2" headers heat insulation/spark plug wires for round course?
Hi all
I am currently installing a set of Kooks 2" headers that are ceramic coated. I wondered which head insulation is needed to protect the starter. As I use my car on the road course, there will be a lot of heat generated? Also, what are people using with regards to spark plug wires? I assume the OEM one's will melt being that close to the 2" header? Many thanks for any help! cirpower |
@viurniel
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT Join Date: May 2016
OEM wires have better (lower) impedance values than most of the aftermarket ones. You can buy sleeves to help.
![]() Drives: 2018 ZL1 1LE Join Date: May 2019
Ive had no problems with my OEM wires with my 2inch headers. They dont touch, but id like to get sleeves eventually.
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial Will buy your GoodYear Supercar 3R Take offs! |
![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
Buy sleeves
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
OEM wires and sleeves. All you need.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
use oem wires with sleeves. Hopefully, you can use the metal heat shield around the plug with your headers. Some have struggled at VIR with burning wires that are close.
#7 |
![]() Drives: 2018 ZL1 Garnet Red Tintcoat A10 Join Date: Jan 2019
Agree as posted above OEM wires have close to Zero resistance nit worth the upgrade. Just sleeve them with heat shield.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
I’m using sleeves and msd wires. The oem wires were fine but I wanted to maximize the distance from the tubes.
#9 |
Thanks for all the feedback!!! Did you guys do anything to protect the starter from the heat? cheers
#10 |
![]() Drives: ZL1 1LE Join Date: Oct 2018
There was also a post recently by someone who melted the bottom of the coolant reservoir and had to apply a heat shield to the bottom of the new one. He had ARH 2” (coated) and was on a road course. https://www.camaro6.com/forums/showthread.php?t=564875
#11 |
Hi all, I am struggling to get the wires connected to the spark plug with the oem metal heat shield and the sleeves. Any tips? Do I need to cut off the springs that sit at the front of the metal protectors or leave them away completely? cheers Cirpower
#12 |
I run the Speed Engineering Wires and Ngk plugs, best I've found and I've run MSD, Taylor and others.
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
i got some msd wires but forgot to get some sleeves gonna get them put on next month
