Old 01-15-2020, 07:28 PM   #1
J.DAMiER
Drives: 2016 A8 Chevrolet Camaro 2SS
Any members have luck getting the A8 shudder fixed at a dealership in/around Tampa?
My A8 '16 2SS has been experiencing the dreaded transmission shudder for a couple thousand miles now, and it's only getting worse.
This is extremely disappointing because this is the first car I've ever bought and I worked my ass off for it. Now I can't even truly enjoy driving it.
I'm aware of the TSB thanks to an earlier thread on here.
https://static.nhtsa.gov/odi/tsbs/20...63890-9999.pdf
My issue is finding a dealership that is not only willing to recognize the issue, but also have the fluid in stock.
Ferman Chevrolet recently had my car for TWO WEEKS claiming they had the fluid available when they did not. They did not provide a loaner vehicle either, and completely forgot to change my oil/rotate my tires.
Have an appointment for Jim Browne Chevrolet Friday morning. Crossing my fingers. Let me know if anyone has had luck in the Tampa area, willing to do anything to get it fixed.
J.DAMiER is offline   Reply With Quote
Old 01-15-2020, 07:39 PM   #2
Unfortunately I can't help you man, but I feel for you and hope you'll find a decent dealership. You are 100% entitled to this job for free, it isn't some kind of favor that may or may not be extended, the dealer will get reimbursed for the job.
Two things you might want to consider, first, since you drove so much with the shudder present, your torque converter may already be toast, so you need a proper service department that is willing to replace that as well.
Second, you may want to get the transmission tuned once it's fixed (flush and maybe new torque converter). I know it technically means giving up the warranty, but a good tune can completely cure all of its quirks. Before you'd ask, mine is tuned with no issues whatsoever, shifts are crisp when needed and soft when just cruising, no shudder, no jerky shifts, nothing. Just a thought.
Old 01-15-2020, 08:12 PM   #3
Here is a post from someone who has just recently had the same fix applied, including torque converter replacement: https://www.camaro6.com/forums/showt...3#post10700543. Might give you some ammunition in case the dealership needs some convincing.
Old 01-15-2020, 08:18 PM   #4
HCI2000SS
HCI2000SS's Avatar
Drives: 2018 Camaro V6/RS
When I read posts like this, it makes me feel extremely lucky that I have a very good dealership that I bought the car from. The very first time I took it in for the latest service bulliten, they not only took it right then and there, but they also replaced the torque converter as well. So there are excellent dealerships out there if you look around
HCI2000SS is offline   Reply With Quote
Old 01-15-2020, 09:40 PM   #5
breakskeet
Kevin
breakskeet's Avatar
Drives: 2018 Callaway Camaro ZL1 1LE
Well I would recommend Ferman!
When I read posts like this regarding someone's issues with a dealership that I have bought 9 cars from over 11 years and never had an issue it shows that opinions vary from person to person.
Too bad you had a negative experience there.
Welcome to the Forum!
breakskeet is offline   Reply With Quote
Old 01-16-2020, 01:44 AM   #6
karmatourer
STD free
karmatourer's Avatar
Drives: 2018 Bright Yellow LGX M6 RS NPP
It isn't his opinion. It's a fact that the dealer didn't do right by him, as he described.
karmatourer is offline   Reply With Quote
Old 01-16-2020, 08:49 AM   #7
breakskeet
Kevin
breakskeet's Avatar
Not looking for a fight bro
I said opinions vary from person to person. Not his opinion.
It is a fact that he states he was done wrong. I'm gonna speculate that his opinion of Ferman is not favorable.
Don't turn my words around.
Old 01-16-2020, 09:50 AM   #8
Zapote21
Tampa Bay Camaros
Zapote21's Avatar
Drives: 2017 Krypton Green 2SS
I took mine to Ferman on North Dale Mabry and they did the service for me in one day. They have really stepped up the service dept since they bought the place from Maus.
Me and wife, in order
2011 2SS SGM
2013 2SS Hot wheels vert
2016 C7 DSOM
2012 2SS yellow vert
2017 2LT Krypton Green
2018 2LT Hot wheels crush
2020 2SS Shock vert.
2017 2SS Krypton Green coupe
Zapote21 is offline   Reply With Quote
Old 01-16-2020, 12:41 PM   #9
redcoats1976
try stingray in plant city,they are a top notch dealer with a good service department.
redcoats1976 is offline   Reply With Quote
camaro, lt1, transmission, transmission shudder, tsb
