Horsepower whisperer
Drives: Camaro Join Date: Jun 2017
FS Callies compstar center balances CCW 4” crank, 2x New Molnar H beam Rods
Up for sale is 2 set of new Molnar Technology H beam rods and 4” Callies Compstar Center weighted (8 counter weight) Crank
If you haven’t heard of Molnar, it is Tom Molnar’s company, Check google and forums, very good quality Both rods are for LT motors: 6.125” length 7/16” ARP 2000 custom Molnar bolts 0.927” Pin Bore 2.225” Big End Bore 0.940” Pin End Width 1.010” Big End Width 1) Molnar Power Adder rating 1000hp- $600 shipped 654 grams This rod is thicker and heavier than regular H-beams offered from other companies, comparable to a Manley H-Tuff Sold 2) Molnar Power Adder Plus rating 1500hp+ -$900 shipped 737 grams This is a very extreme duty rod Sold 3) Callies custom order 4340 Forged Compstar 4” Stroker Crank with 8 counterweights/center counter balanced (CCW)!! $1100 shipped Majority and the OEM crank only has 6 counter weights and is not center weighted. The 2 additional counterweights substantially stiffen the crank to prevent flexing and yields higher strength for more HP handling. This CCW feature is not normally found on more budget friendly cranks, especially not on the Gen V LT series engine (LT1, LT4, L83, etc) This Crank is rated for over 1200HP!! This was a custom order and a substantial weight time. Cranks works with 6.125” length rods (see my other auction) and pistons designed for 4” stroke, comes with a 58X reluctor and the correct wet sump snout for the Gen V LS engines. (please consult your engine builder) Last edited by Goohead; 01-30-2020 at 05:38 PM. |
Bump
Plus rods and crank sold
![]() ![]() Drives: 2016 2SS coupe 2015 3LT Stingray Join Date: Aug 2012
Are the rods still available
Ported intake manifold and throttle body kooks 2" headers no cats
