Old 01-13-2020, 03:53 PM   #1
scantone
Drives: 18 Z1E - 18 Raptor - 17 Jeep SRT
Best Oil *Not Concerned With Warranty*
Car has heads, cam, lower pulley & headers so warranty lol gone. I also live in Tampa Fl so cold weather is not a concern either. Love to hear some opinions.
scantone is offline   Reply With Quote
Old 01-13-2020, 04:17 PM   #2
RDBill
902HP 858TQ
RDBill's Avatar
Drives: 2018 ZL1 A10
I love Mobil 1 warranty or no warranty... In my younger days I had a drag race car that was trailer to and from the track I used Red Line oil which still may be the best but more expensive. You can't use "race" oils in a street car and would imagine your not going to find a big difference in the top brands like Mobil 1
RDBill is offline   Reply With Quote
Old 01-13-2020, 05:10 PM   #3
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
Money no object, I prefer Amsoil and Motul for emissions systems safe oils.
But for a hard-driven race car seeing 250F+ frequently, with no concern about emissions components, I'll admit I'm old school and like high ZDDP oils despite some people saying the benefit is negligible.
Mobil 1 Race oil comes in 0w30 and 0w50 and has 2-3x the ZDDP of standard M1, they run it in many pro race cars including Corvette.
I was sponsored by Lucas oil for 2 years and always used their synthetic Racing oil in 0w40 and 20w50. I often mixed it for colder track days. This oil had 3000+ ppm ZDDP which is the highest I've ever seen--over 50% higher than M1 Racing.
When an oil line fitting failed unnoticed on the Dyno on my 500 WHP Evo X 2.0L 8500 RPM race motor, it quickly ejected 5QTs of oil while running 27 psi pulls to red-line several times until a fire ignited under the car (and we noticed the problem). The engine was dis-assembled and I assumed there would be severe oil starvation damage... there was zero apparent damage to bearings, rods, pistons, sleeves, only a slightly damaged cam that had to be replaced. I was running Lucas Racing 10w40/20w50 50/50 at the time.
SFV1LE is offline   Reply With Quote
Old 01-13-2020, 05:52 PM   #4
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
torco 5w40 sr1 is what i use year found good stuff
https://torcousa.com/
Old 01-13-2020, 06:45 PM   #5
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
If you haven't seen the Project Farm videos, then check this out:
Old 01-13-2020, 07:07 PM   #6
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
I use Harvest King.
ssmofo is offline   Reply With Quote
Old 01-13-2020, 11:10 PM   #7
Too_Fast
Too_Fast's Avatar
Drives: 2017 Camaro ZL1
I use Driven LS 30 racing oil. Recommended by Vengeance when did my upgrades.
2017 ZL1 White A10 ... Vengeance Racing - custom camshaft, CNC aluminum ported heads, engine internal upgrades, SC pulleys, Rotofab CAI, ported TB, Kooks headers, Corsa Sport exhaust cat back with black tips, Incurve Custom Wheels.
Too_Fast is offline   Reply With Quote
Old 01-13-2020, 11:32 PM   #8
Techdude99
Techdude99's Avatar
Drives: 2019 Chevy Camaro ZL1 1LE
I lived in Clearwater for 30 years. With that climate, Motul or Mobile 1.
Techdude99 is offline   Reply With Quote
Old 01-14-2020, 05:23 AM   #9
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
My mods are similar to yours and I drive in the Georgia heat. No cats so I use Mobil 1 0W-40, non dexos. Always ran it in my heavily modded, cammed 2005 GTO and every time we opened up the engine to add additional mods, it was always exceptionally clean and remarkably free of unusual wear.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 01-14-2020, 11:41 AM   #10
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
Hey all, wanted to weigh in on what most do not take into consideration on proper oils that are the best for your engines life, etc.
The first thing to realize is your engine is a GDI engine. Gasoline Direct Injection. So, right from the start your engine oil has to deal with 8-12 times the raw fuel pushed past the rings washing lubrication from the cylinder walls and diluting the engine oil. At 5% dilution oil is considered "condemned" and no longer able to protect properly. Now combine that with the super light viscosity oils that are specified today NOT because of "tolerances" and other lip service, but it is so that platform and engine will meet CAFE international fuel economy standards period.
This is why GM changed the recommended viscosity to a 0w50, etc. due to failed bearings, etc. when tracking.
Next, you have to look at the issue of LSPI (Low Speed Pre Ignition) that we have been discussing for years now before any of the recent articles on this have been shared. LSPI is a phenomena that was basically unknown before GDI engines were forced onto the industry far before being perfected. (Another reason engine warranties are now 1/2 of the period the old port injection engines were). LSPI is where fuel is forced behind the piston rings and mixes with crankcase oil vapors. If this ignites, it is a very unstable and violent explosion that breaks the ringlands at the least serious failure, and entire pistons for catastrophic failure. While our Crankcase evacuation systems designed for these engines prevents this, and removes most of that excessive fuel before it can settle and mix with the engine oil, eliminates this, Amsoil, M1, and a few other premium oils have changed formulation to include additives that render this mix far less explosive. So a good FULL synthetic only (the blends are the worst as it is the petroleum based oil components that compound this issue.
Then you need to look at the amount of particulate matter shed and also contaminating the crankcase oil, and the average oil filter does not remove the smaller micron sized particles so wear is always a concern. Again, our E2-X systems convert the PCV system to full time evacuation and remove most of this as well before it has a chance to settle and mix.
So, when we look at ZDP additives, they provide scuff protection that was needed for flat tappet camshafts, and as all today's engines are roller valvetrain, that is not as critical as a proper viscosity and full synthetic. Amsoil Signature series 5w50 flows well cold for most climates, and once up to operating temp provides that added viscosity to combat the fuel dilution, etc. So oil filter choice is critical also. AC Delco makes great filters, as Wix, Pureolator, etc.(NAPA Gold).
For those in extreme cold climates, M1 makes a 0w50 as well.
Here is a oil sample at over 13k miles showing how well oil remains clean and lasts far longer (protecting far more) when our E2-X system is used. The next sample will be at 20k miles. This is a twin turbo GDI engine making over 20# boost so subject to far more stress on the engine oil than a NA engine:
https://s1083.photobucket.com/user/tech17/media/Falcon%20long%20term%20testing_zps7l9mvzrs.jpg.htm l][IMG]https://i1083.photobucket.com/albums...ps7l9mvzrs.jpg[/IMG][/URL]
And a piston with the most common LSPI damage. Uses oil and has misfires...dealer diagnoses is "no problem found" as they will not perform a leakdown test, only a compression test and that will not isolate the issue.
https://s1083.photobucket.com/user/tech17/media/IMG_13781_zpsqqljhuaj.jpg.html][IMG]https://i1083.photobucket.com/albums...psqqljhuaj.jpg[/IMG][/URL]
So, think about these aspects of caring for a GDI engine that was never a concern in the past.
Questions? Just ask.
Direct email to our Engineering and technical support team? Tech@EliteEngineeringUSA.com
Elite Engineering is offline   Reply With Quote
Old 01-14-2020, 12:26 PM   #11
viurniel
@viurniel
viurniel's Avatar
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT
The 'best' oil will be relative to the application. Are you referring to daily driving, with occasional spirited driving? Are you referring to full time race-car?
For an easy all around, Mobil1 15W-50: cheap, high viscosity, great for warm climate, will provide more than enough protection,and it is the recommended track oil. Also, unlike our friends to the north of Florida, we can get away with high W numbers (15W-20W).
viurniel is offline   Reply With Quote
Old 01-14-2020, 12:30 PM   #12
scantone
Thanks everyone for the opinions, I went with the Amsoil 5w50.
