Old 01-13-2020, 04:38 PM   #1
petek8103
petek8103's Avatar
Drives: 2019 Camaro ZL1
Header and Tire Questions
So I'm hoping somewhere here has the AWE Track Exhaust connected to after market LTHs. Any recommendations on what should bolt right up to the AWE-CATBACK?
Looking at replacing the factor tires and keeping the stock 20 inch wheels. Can anyone confirm of the Toyo Proxes R888R will fit without rubbing?
petek8103 is offline   Reply With Quote
Old 01-13-2020, 05:53 PM   #2
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS, 2010 Camaro SS
OP we have installed several after market cat-back exhaust systems on 6th gen Camaros with headers and none of them direct fit together with a different brand exhaust. You will have to modify the header's connection pipe or the Cat-Back exhaust pipes in order to make it work. We installed a AWE Cat-back to a 6th Gen ZL1 Camaro with long tube headers and we cut the Cat-Back pipes short so it would bolt onto the header's connection pipe with the provided hardware. If you wanted a true bolt on experience without any modifications I would suggested purchasing a complete Headers/exhaust system like American Racing Headers or Stainless Works. Here is a link to some of their exhaust systems available on our website with 1 7/8 Headers. Keep in mind a tune is required when you install headers so you need to find someone locally to make a custom tune on your ZL1.
Regarding Toyo Proxes we offer the front factory ZL1 tire size of 285/30 R20 so you can have an exact replacement. If you want to install the rear Proxes then we suggest you use a 5mm spacer with a 315/30 R20 and you could lower the car too with some springs and still be fine.
-Trae
Sales@Phastek is offline   Reply With Quote
Old 01-13-2020, 09:50 PM   #3
Markoz28
Drives: 18 ZL1 nightfall grey A10
315/30/20 R888Rs will fit fine on the 11” wide whee. Like stated before you will need a spacer. I would also move the wire harness in a bit. Super easy to do. Took me 45min and most of that time is removing the wheel from the car.
Markoz28 is offline   Reply With Quote
Old 01-13-2020, 10:45 PM   #4
Zigg L1
Zigg L1's Avatar
Drives: 2018 ZL1 Garnet Red Tintcoat A10
I thought from everyone else that the 315/30/20 tires fit great on the zl1 with no adjustments needed?
Zigg L1 is offline   Reply With Quote
Old 01-13-2020, 11:29 PM   #5
PROMETHEUS
PROMETHEUS's Avatar
I have the AWE Track Edition with Performance Link Pipes. Unfortunately there is no LTH manufacturer that bolts directly up with the AWE system. There has to be some additional modifications done to marry the two up.
Old 01-14-2020, 10:36 AM   #6
petek8103
petek8103's Avatar
Thanks everyone for the quick replies, any recommendations on Headers? I was told that 2inch is the way to go. Not sure about that as I have read they rub and have fitment issues.
Old 01-14-2020, 11:40 AM   #7
The difference between 1-7/8 and 2" is negligible. I wouldn't even give that a second thought, but either way if you do want perfect fitment go with ARH. The stories you've heard are other brands and ARH is GM certified for our cars.
Old 01-14-2020, 11:52 AM   #8
Road Pressence
Road Pressence's Avatar
Drives: 2019 Satin Steel ZLE
You can do ARH long system that comes all the way back right before the stock muffler then get an aftermarket axleback. Thats probably the easiest way to make it fit correctly instead of trying to get headers to mate with catback.
Road Pressence is offline   Reply With Quote
Old 01-14-2020, 01:24 PM   #9
petek8103
petek8103's Avatar
Thank you all for the quick reply, I already have replaced the entire system and even the secondary cats are gone, I'd like to salvage that if possible.
I was thinking these -- https://kooksheaders.com/2-headers-conn1317
It looks like their mid-pipe ends where the AWE CAT-BACK would connect i would think it's pretty close.
Old 01-14-2020, 02:17 PM   #10
Sales@Phastek
You would have to modify the AWE pipes or the Kooks connection pipe to make them fit together. I suggest asking your tuner for their recommendation on if you should get the 2" or 17/8" headers for your Camaro. Here is a link to those 2" Kooks headers with offroad connection pipes on our website and a link to the 1 7/8" ones.
-Trae
Old 01-14-2020, 08:59 PM   #11
Markoz28
You can for go the spacer but you cannot for go the wire and inner liner. This must be move or adjusted or you can rub right through it
Old 01-14-2020, 09:22 PM   #12
Zigg L1
Zigg L1's Avatar
Markoz I don't mind the spacer and moving the harness just going off of everyone's expert opinion. Thanks for the reply. Which size spacer? 5mm?
Old 01-14-2020, 09:57 PM   #13
Markoz28
5mm will be plenty. I don’t think you’ll need one but if so I’d go 3mm and that’s just to give a wider stance.
Old 01-14-2020, 10:02 PM   #14
ZL1naples
Drives: 2019 ZL1
You absolutely do not need spacers. I run the proxes 315 30 20s on the rear with no rubbing issues whatsoever. I did move the cable "just to be sure." You should not use a spacer if you don't need it. My car is a 2019 ZL1 A10. Those that claim you need to use spacers are simply wrong. My comment may or may not apply to a lowered car-I have no idea for a lowered vehicle.
ZL1naples is offline   Reply With Quote
