1khp_1le
Drives: 2019 1LE/ss 2014 ss/rs summit white Join Date: May 2016
Procharger Cam
I’m looking to build up my engine in the next few months and I want to prep it for a procharger further down the road -94 or d1x so what I’m looking into part wise and getting is as follows.
Gpi drop in piston/rods Cam that I can be N/A with great power that will also be great with a procharger (Ss4 from gpi, who also says that will work) but being told by others it won’t MSD I/M Headers Car already has a Roto-Fab and E installed So looking for my best options and suggestions along with why or why not they will work. Thanks look forward to reading everyone’s responses. |
SS4 is too much cam for a FI street car. It has 17.5 degrees of overlap. Hit Pray up for his Stage 2 blower cam.
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2018
Have you talked to anybody from GPI or just visited the website? I'd call them if you haven't and pick their brain.
1khp_1le
1khp_1le
Fwiw There is a local car that has gpi forged drop-ins, ss4 cam(recommended by gpi. Rep), and P1 Centri. The car made good power on the Dyno, but the cam bleeds off so much boost the P1 gets smokin hot from being over spun to make 11-12psi with IAT's pegging 180. I'm sure a F1a would work better but imo it's still the wrong cam.
A Centri cam in a NA application would work better then a large NA cam in a Centri application.
#7 | |
1khp_1le
#8 |
![]() Drives: 2017 2SS, M6, Silver Join Date: Jun 2018
like KingLT1 said get with Pray on his stage 2 blower cam. i currently have that cam in my car and my car has been above 1xxx WHP with out a hiccup with his tuning and has plenty left in it for more power. beware though one thing we learned and GPI will admit is that the rods in their drop in kit are not rated past 900 ( dont know if you are planning on going past that just and FYI). now my car is getting a custom built and forged 416 with a cam based off the stage 2 blower cam because it fits FI builds so well. if you need any specific information i am more than happy to help you get squared away!
17 2SS, Pray Performance Forged/Stroked 416, 2.9 Whipple (Pray ported), Stage 2.5 Pray ported heads, RotoFab Big Gulp, Katech 103mm TB, Pray Performance stage 3 forced induction cam, 8.855” crank shaft lower pulley, 3.00 S/C pulley, LT4 Fueling, SMG auxiliary fuel system, 2' TSP LT headers with X-Pipe, Magnaflow Competition axleback, Mighty Mouse Wild catch can, Hurst Short Shifter. Tuned by Pray Performance. 1011WHP/982WTQ
#9 | |
I personally would do something around a 226/242 114-115 with 4-6 degrees of overlap.
#10 |
![]() Drives: DZ Join Date: Aug 2018
230+ duration intake cams are going to really make the car a POS to drive, especially without the blower. Im not sure if your car is a auto or manual, but if its an auto it will need a stall, and if its a stick it is going to buck under low load.
If you want a good cam that will be OK both N/A and good on a Procharger, the BTR Supercharged Stg1 or 2 would be good choices, and prooven. |
#11 |
![]() ![]() Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
I went with a cam from pray performance that is bigger then his stage 2 boosted cam. Only thing that will happen if your running a boosted cam on your NA setup is your power won't be as high as other NA built specific cams.
Either way i'd contact pray and grab his Stage 2. I went with a slightly bigger setup as my power goals are to be more then 1000whp
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
#12 |
1khp_1le
Thanks everyone for reaching out. I’m waiting for a few shops to get back with me on a better(suggested piston/rod combo) to see where we stand with the build. One place wanted to just jump straight to a resleeved 427 but not looking to go that route yet.
#13 |
http://www.cammotion.com/gen-5-lt-ca...ger-camshafts/
Cam Motion is the only people I know that make a specific centri cam. You can order any duration and any lobe profile. I went with a sub .600 lobe. I went with a 230+ duration cam just cause I WANTED the lope, my original zero overlap Pray stage 1 or 0 depending was just too mild, very hard to tell it was NOT stock. The Cam Motion defined lope cam leaves no doubt.... was not a power mod. I have an m6 and feel the cam is completely totally drivable... I have a idle / rev video on the NA section. Will do one soon with a 100% stock exhaust system, at 45 MPH it really behaves and sounds like stock. In the parking lot it sounds like a BIG cam even with a near stock exhaust.
#14 |
![]() Drives: 2017 camaro 1le Join Date: Aug 2017
i have a tick performance stage 2 blower cam, i can post the specs if you would like
| Tags |
| procharger d1x |
