Old 01-12-2020, 09:45 PM   #1
ohsmily
Drives: '19 ZL1 1LE A10 ShadowGrayMetallic
Track helmet for n00b. UPDATE POST #37
I have only one day on the track and it was with an instructor with Hooked on Driving. I plan to go 2 to 3 times per year and wanted to purchase a helmet of my own rather than rent as I did the first day.
I know this isn't a track forum per se, so i'll loosely tie it to the sub forum by asking if you can recommend one that is suitable but also fits well in the driver's seat of a ZL1 1LE. My budget is max $1000 unless there is a good reason to go higher.
I was looking at this:
Sparco 0033442M Sky RF-7W Carbon Racing Helmet Medium https://www.amazon.com/dp/B01MXF37LI..._mE9gEbMV81R1Q
Thank you in advance.
ETA See additional question regarding duck bill feature in post 13 below.
FINAL EDIT: I went with the Stilo ST5. Did the electronic comms model and bought an extra headset for instructor/ passenger. Bought in person from Wine Country Motorsports. I was passing by on way back from work in Marin Co.
ohsmily is offline   Reply With Quote
Old 01-12-2020, 09:55 PM   #2
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
I love my Simpson Devil Ray, but it's Carbon Fiber and a bit pricey. I'd recommend the Stilo ST5 is a great helmet. I'd also ask you to up your budget and add a Simpson Hybrid-S with the helmet.
https://store.windingroad.com/stilo-...BoCKcoQAvD_BwE
https://store.windingroad.com/simpso...ved-p2193.aspx
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 01-12-2020, 09:58 PM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
The helmet you selected is obnoxiously expensive for a Snell SA2015. You could easily save a few hundred dollars and have similar protection.
Old 01-12-2020, 10:10 PM   #4
Road Pressence
Road Pressence's Avatar
Drives: 2019 Satin Steel ZLE
Id check out the racequip helmets for a nice budget helmet that you can use for local track days.
Road Pressence is offline   Reply With Quote
Old 01-12-2020, 11:41 PM   #5
Rnovrit
Drives: 2018 NFG ZL1-1LE
Pyrotech makes really nice helmets. I have one I use for racing and it is super comfortable. Their customer service is great as they are a family run operation.
Rnovrit is offline   Reply With Quote
Old 01-13-2020, 12:17 AM   #6
Dixie ZL1
NOXQCES ZL1
Drives: 2017 Camaro ZL1
I really like my Bell open face. Inexpensive at $300 and comfortable.
Dixie ZL1 is offline   Reply With Quote
Old 01-13-2020, 12:28 AM   #7
amolaver
Drives: 18 ZL1 E90M3 E36M3 SM NCMX5
For an occasional track day, gforce SA helmets are great.
http://www.gforce.com/category/helmets/
Hell, I've been using them for more than a decade of road racing. Reasonably priced and well made. Don't have the bling factor of an Arai or stilo etc, but work. My first one survived a near 100mph impact into a tire wall while tethering my HANS. I replaced it with another gforce
Also keep in mind the SA standard will be updated in 2020, so the SA2015 helmets should be dropping in price. https://www.pegasusautoracing.com/do...ocID=TECH00153
If you want to drop serious coin, the high end helmets are great..but for an occasional track day, you absolutely don't have to. If you really want something that provides more protection, look into FIA 8860-2018 helmets...but be prepared for sticker shock.
ahm
amolaver is offline   Reply With Quote
Old 01-13-2020, 12:33 AM   #8
ohsmily
I'm surprised at the variety of suggestions. There clearly isn't a consensus on helmets for my type of use.
One poster mentioned Pyrotect. The helmet I rented seemed similar to this and seemed to work and was comfortable.
https://pyrotectstore.com/product/pr...en-face-sa2015
Is full face preferable for safety? Anything wrong with this helmet? I don't mind spending a grand or a bit more if I'm getting a meaningful benefit from getting the more expensive option.
Old 01-13-2020, 12:52 AM   #9
amolaver
Pyrotect makes good stuff too. I'd strongly recommend a chin bar model like https://pyrotectstore.com/product/pr...h-visor-sa2015 I use a GForce like that - 'full face' but no visor. In a closed cockpit car, I almost always wear sunglasses while driving and I find a visor to be annoying; almost everyone runs with it up, so why have it. In an open cockpit car (or a motorcycle), a visor is a necessity.
If you can wait till April/May, the SA2020 helmets will start to be stocked and the SA2015's will be significantly cheaper.
I'd strongly recommend you find a retailer and test-fit any model you want. Helmets are made in slightly different shapes, but small differences can be hugely annoying/uncomfortable. For example, I can wear one style of Arai (round oval) for hours on end, while their 'long oval' style i find massively uncomfortable inside of 15 minutes.
ahm
Old 01-13-2020, 01:32 AM   #10
UFDUB
Drives: Chevrolet Camaro ZL1 1LE
I recommend Pyrotech as well. Comfortable, reasonable, fit well, not overly expensive. Very happy with mine and I use mine for occasional track use as well. If I ever track more often, may upgrade but I don’t see any reason to at this point.
UFDUB is offline   Reply With Quote
Old 01-13-2020, 09:05 AM   #11
PROMETHEUS
PROMETHEUS's Avatar
No reason to spend that kind of money on a helmet, especially if you first getting into this hobby.
Old 01-13-2020, 09:47 AM   #12
Junkyardspecial
Junkyardspecial's Avatar
Drives: 2018 ZL1 1LE
Racequip, zamp, Pyrotech, all very good budget helmets. as long as its SA2015 and ap roper fit and comfortable for you, that should be all that matters.
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial
Will buy your GoodYear Supercar 3R Take offs!
Junkyardspecial is offline   Reply With Quote
Old 01-13-2020, 11:41 AM   #13
ohsmily
I noticed that many of these helmets have a duck bill option that has the protrusion below the chin area presumably to prevent or reduce neck injuries from the head being slammed forward during a frontal collision. Do you guys recommend that duck bill design or does it restrict movement too much for my purposes?
Here is an example:
https://pyrotectstore.com/product/pr...ill-white-copy
Old 01-13-2020, 11:53 AM   #14
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
Pyrotect or Bell is all I ever use, make sure it's an SA approved helmet, most driving places wont let you wear a motorcycle helmet either. I would never wear an open faced helmet either.
ssmofo is offline   Reply With Quote
