Old 01-12-2020, 03:57 PM   #1
Checkmate1
Drives: Garnet Red / ZL1 1LE
Exclamation Modifying the Stock Exhaust (Muffler) Box
Anyone do this?
I want to retain the stock exhaust box but curious if any muffler shops have done any wizardry with this box.
No muffler delete as I know drone is a huge issue with muffler deletes from owners.
#SAVETHEMANUALS
Checkmate1 is offline   Reply With Quote
Old 01-12-2020, 04:55 PM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
You didn't state any reasoning behind this, but in case you hadn't seen or heard, but these mufflers pose little to no restriction and much loss of power. CSP performed a comparison with the stock axle back (AB) and AFE's AB (I believe it was that one...) and the gains were like a handful of horsepower on an 800-plus RWHP car. That AB also featured the NPP-valves so it was essentially open for the test, too.
Anyways - best of luck.
'20 ZL1 Black "Fury"
Old 01-12-2020, 06:03 PM   #3
Checkmate1
My only reason is more sound. Not looking for performance gains.
Essentially, more sound with no drone.
I already have the Secondary CAT deletes done and it is marginally louder with more pops and crackles. That being said, I would like some more sound if it is easy enough for a muffler shop to handle.
#SAVETHEMANUALS
Old 01-12-2020, 07:45 PM   #4
SouthFloridaGTO
Drives: 2005 GTO, 2019 Camaro ZL1
Not much HP, but it is a pretty significant weight reduction, as far as weight reduction goes on these cars.
SouthFloridaGTO is offline   Reply With Quote
Old 01-12-2020, 08:09 PM   #5
MarineZLE
Drives: 2015 Z28
Originally Posted by Checkmate1 View Post
Anyone do this?
...curious if any muffler shops have done any wizardry with this box.
You mean like the C6 Z06 muffler mod?
MarineZLE is offline   Reply With Quote
Old 01-12-2020, 08:35 PM   #6
Cleancoupe
Drives: 18 ZL1 1LE
To my surprise I didn’t save much weight at all getting rid of the factory exhaust.
Awe touring cat back non resonated with performance link pipes: 76.2lbs
Tips (4): 6.6lbs
Muffler (2): 29.2lbs
Mid pipes: 30.2lbs
Link pipes: 5.6lbs
Clamps: 4.6lbs
Factory NPP cat back: 79.2lbs
Muffler: 42lbs
Mid pipes & secondary cats: 37.2lbs
Cleancoupe is offline   Reply With Quote
Old 01-12-2020, 09:16 PM   #7
JasonSB
Drives: 2018 ZL1
You want more sound then get headers. Headers and stock exhaust sound like ass. I added resonators right behind the stock suitcase which deleted the crushed section of the stock exhaust and it sounds good now. Im going to replace the stock tips with 4 inch black tips.
2018 ZL1 A10 - Rotofab Intake, LT5 TB, TSP Headers, ATI Balancer, 9.1 Lower Pulley, JMS BAP, Flex Fuel.
JasonSB is offline   Reply With Quote
Old 01-12-2020, 10:50 PM   #8
Checkmate1
No intention of getting headers or doing a muffler delete.
I am looking for something like the C6 Z06 muffler modification.
#SAVETHEMANUALS
Old 01-13-2020, 12:06 PM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
You could probably cut "doors" into the mufflers right above the perforated pipes are, weld-in non-perf' pipes, and weld the "door"s shut. That's the NPP-mod if I recall. In that case, though, you loose the benefits of the NPP, if I'm visualizing correctly.
FWIW - to the OP regarding replacing the OEM can: I think I read somewhere the OEM-can has some aero' that it contributes to (i.e. for the rear facia diffuser). There could be some thermal events but removing the can in extreme driving conditions (i.e. tracking). Having looked around there on mine, I can see what they're talking about, but it's whatever you prefer.
Old 01-13-2020, 12:10 PM   #10
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Unless you weld in cutouts before the suitcase, what you're envisioning won't do anything. Have you seen the NPP muffler cutaway? The outside pipes are a muffler bypass with only a few perforations in the piping.
Old 01-13-2020, 02:57 PM   #11
ramairroughneck
Drives: 2018 Camaro SS
What length resonators did you use? I’d like to add 18” ones right after the X but they may be tough to fit. It’s looks close
ramairroughneck is offline   Reply With Quote
Old 01-13-2020, 03:07 PM   #12
zincgt
zincgt's Avatar
Drives: 2017 A10 ZL1
pull the npp fuse and it will keep the valves open 100%, my car is loud as hell on the outside but on the inside I wouldn't be able to tell. Its deceiving.
zincgt is offline   Reply With Quote
Old 01-13-2020, 04:17 PM   #13
Laststandard
Drives: 2018 1SS 1LE
NPP exhaust cutaway. Really nothing to mod inside the case. I wouldn't attempt to replace the perforated section with a solid pipe, if you do that and happen to hook the NPP system back up bad things will happen.
Secondary cat delete will get a bit of extra sound.
2018 1SS 1LE (sold)
Laststandard is offline   Reply With Quote
Old 01-13-2020, 04:26 PM   #14
FoundNemo
Drives: 2019 ZL1
Connect the inlets to both of the outlet pipes and enjoy. Then you dont have to worry about what happens if you hook up NPP again.
FoundNemo is offline   Reply With Quote
