Old 01-12-2020, 11:26 AM   #1
dbvettez06
Drives: 2001 corvette Z06. 2018 ZL1
Oil Change. HELP
Owners manual says 0w40. And 5w40
The oil cap says. DEXOS 5w30.
What the heck gives ???????
dbvettez06 is offline   Reply With Quote
Old 01-12-2020, 11:36 AM   #2
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I think db the 2018 takes 5W30 but I would go whatever the manual says to use! I know my 2017 takes 5W30 and that’s what I put in when I changed it last time.
Old 01-12-2020, 11:52 AM   #3
LT4Greg
LT4Greg's Avatar
I just checked the Owners manual supplement for the 2018 ZL1 and the oils you listed are for competition/track events so I would assume if you are mainly driving on the street then the oil grade is 5w30. Did you get a supplement to your owners manual? I looked it up on the web and found the info.
Old 01-12-2020, 11:56 AM   #4
LT4Greg
LT4Greg's Avatar
Maybe some other ZL1 owners will chime in on this thread!
Old 01-12-2020, 11:58 AM   #5
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
5W30 was replaced with 0W40 in 2019. I made the switch and replaced the oil cap. 0W40 can be used on the street and the track for the ZL1s. ZLEs have to switch to 15W50 for the track.
Old 01-12-2020, 12:01 PM   #6
dbvettez06
Uhhh my dumb. Owners manual says 5 40 for track use age. I can blame it on being a Veteran ��
For street usage I’ll do the GM 5w30 just to keep the extended warranty people happy.
Old 01-12-2020, 01:16 PM   #7
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
I think all LT4's should be using 0w40 2dexos 5w30 was superseded by it
2019 Crush A10
E-Force 2650
670WHP 615WTQ
All besides the 2650 is bone stock down to the air filter.
gotswap is offline   Reply With Quote
Old 01-12-2020, 01:21 PM   #8
viurniel
@viurniel
viurniel's Avatar
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT
Mobil 1 0W-40 Dexos 2 is the right stuff.
viurniel is offline   Reply With Quote
Old 01-12-2020, 01:21 PM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
You can use the 5-30 dexos as a substitute if the 0-40 isn't available. 15-50 were ZLEs for track use only and was to be switched immediately back to 0-40 after tracking. I'm sure dexos 5-30 is just fine otherwise. I imagine the 0-40 dexos2 is for the PVC and DI playing well together.
'20 ZL1 Black "Fury"
Old 01-12-2020, 02:48 PM   #10
LT4Greg
LT4Greg's Avatar
I will keep using 5w30 for general use in my 2017 because it is specified in the owners manual. The 2019s and 2020s are designated to use 0w40 for street usage.
Old 01-12-2020, 06:59 PM   #11
dbvettez06
I wonder why the change in viscosity from 18 to 19 ??
Old 01-12-2020, 07:26 PM   #12
LT4Greg
LT4Greg's Avatar
I couldn’t tell you that. I have no clue!
Old 01-12-2020, 07:36 PM   #13
BobZL1
BobZL1's Avatar
Drives: 18 Stingray,19 ZL1
My 19 ZL1 specs 0w40 dexos 2. It’s in the owners manual and on the oil cap. It’s the same engine as a 17 & 18. I would use it in an earlier car if it was me.
BobZL1 is offline   Reply With Quote
Old 01-12-2020, 07:57 PM   #14
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
For Street use you're totally fine using 5w30 dexos 2 Mobil 1. 0w40 ESP Mobil 1 is a good all-around Street / track oil
