![]() Drives: 11 Corvette ZR1 Join Date: Jul 2017
Code P0442, where is the purge valve?
My 18 SS has that code after header and no cat install. Says purge valve, can anyone point me to where it is ? Every time I clear it comes back after a few days.
Thanks Jay
11 Corvette ZR1
18 Lexus GX460 19 Yamaha FX Cruiser SVHO |
![]() ![]() Drives: 2021 300 Join Date: Jan 2015
Saw that video but thought it might be different in the 6 gen. Thanks
11 Corvette ZR1
![]() Drives: 2018 Summit white 2SS 1LE Join Date: Nov 2016
The purge valve solenoid is located on the intake manifold left of the throttle body. The vent valve is the one located on the evap canister.
Thanks man, will try to change it tonight.
11 Corvette ZR1
#2 in this picture:
#7 |
very cool, thanks man
11 Corvette ZR1
#8 |
![]() Drives: 2016 SS Camaro Convertible Join Date: Nov 2018
Where does the other end connect?
Does anyone know what the other end that connects into the EVAP canister purge solenoid valve is connected to? I have looked everywhere and can't find an answer?
#9 |
The other end connects to the evap canister back near the gas tank.
#10 |
Ready, replaced last night. Check engine went away but do not know if it was because of the new purge valve or because I disconnected the battery. But the error before used to read Pending, Current, Permanent. Now it only reads Permanent.
11 Corvette ZR1
