Old 01-10-2020, 06:29 AM   #1
Rodsingod
Drives: 2016 Camaro SS
Question Looking for help
Here in New jersey i need to register my 2016 ss, i know for a fact that i won't be able to pass emissions. i bought the car and found out it is pretty much straight piped. any advice for passing?
Rodsingod is offline   Reply With Quote
Old 01-10-2020, 06:50 AM   #2
wingchunsifu
wingchunsifu's Avatar
Drives: 2017 2SS A8, 2026 BMW X1 M35i
Unfortunately, you have to re-install the Cat. The old days of passing it using the exhaust from another vehicle or having a repair guy you know "hook you up" are long gone. Nowadays everything is computerized and tracked. Here in NY, the only thing they can push through is the dark tints. Let's see how long that lasts.
wingchunsifu is offline   Reply With Quote
Old 01-10-2020, 07:14 AM   #3
slimjim2525
Drives: 2019 Camaro 2SS
Yeah sorry, especially in NJ, you're out of luck.
2019 Camaro 2SS, Shadow Grey
slimjim2525 is offline   Reply With Quote
Old 01-10-2020, 08:38 AM   #4
MiamiBlueCamaro
MiamiBlueCamaro's Avatar
Drives: Gen 6 Camaro RS
You are not far away from this place, cheap labor and may be able to help you in your situation.
Old 01-10-2020, 08:58 AM   #5
L78toLT1
L78toLT1's Avatar
If you happen to have a very good friend with a 6th gen SS, you could borrow his exhaust for the emissions test. The entire exhaust from the manifolds back can be swapped in under an hour, working off of Jack stands.
Baby Blue
Old 01-10-2020, 10:54 AM   #6
Rodsingod
fix mufflers.com?
Old 01-10-2020, 10:55 AM   #7
Rodsingod
by the way, thanks for the quick replies everyone.
Old 01-10-2020, 11:15 AM   #8
MiamiBlueCamaro
Originally Posted by Rodsingod View Post
fix mufflers.com?
Yes and there are a bunch of them in the area.
Old 01-10-2020, 01:07 PM   #9
Fraxum
Fraxum's Avatar
There are also "Friendly" NJ inspection locstions.
Old 01-10-2020, 01:37 PM   #10
wwiiavfan
Drives: 2017 1SS Hyper Blue
I thought they hooked up to the OBD port and if everything checks out, you're good. No sniffers anymore.
Assuming the OP is catless and no O2 sensors, and has a tune that gets rid of CEL's, does the emissions check see that tune and throw a flag?
Is that what he means by know for a fact it won't pass?
So many questions...
wwiiavfan is offline   Reply With Quote
Old 01-10-2020, 02:26 PM   #11
CrazyCatGuy
I'm the cats pajamas baby
Drives: 2018 Camaro SS 1LE
I guarantee as soon as he rolls in to the shop with a straight piped camaro, they'll know what's up. Not like he'll be the first guy trying to pass off a non catted car.
CrazyCatGuy is offline   Reply With Quote
Old 01-12-2020, 08:35 PM   #12
Rodsingod
thanks for the info. to reply to one of the previous post i don't think there any more friendly NJ inspection shops anymore particularly in the northern NJ area, also i haven't been throwing up any codes i just know with the way it sounds they will probably think i'm insulting their intelligence.
Old 01-15-2020, 03:08 PM   #13
TobyinNJ
Drives: 2018 Camero SS 1LE
How did this work out for you? I moved to NJ with a Subaru STI which had to run a special lean tune to scrape through the emissions tests in CO. I took it to the testing place in Flemington and the guy told me that as long as it isn't throwing codes when they plug it in, it would be fine. I took it there, didn't change the tune, and was out with my sticker in 5 mins. Probably not as loud as a straight pipe LT1, but with a 3" Perring exhaust, it wasn't exactly quiet.
TobyinNJ is offline   Reply With Quote
Old 01-15-2020, 04:55 PM   #14
DannyC
Drives: 17 Camaro SS
You can buy 18mm anti fowlers from a parts store, drill them out so the O2 sensor will not hit bottom, then install anti fowler in O2 bung and the O2 sensor into the anti fowler. It keeps the sensor out of the exhaust so shouldn't throw a code for no cat.
Flow Tech axle back, Roto-Fab, Nick Williams 103, AEM Wide Band, Defrost vent pod, billet catch can, BBK long tube headers and NGK LTR6GP, #90198, one step colder, Magnuson 2650, Snow Performance water/methanol injection. (Also tune myself w/HPTuners)
DannyC is offline   Reply With Quote
