Go Back   CAMARO6 > CAMARO6.com General Forums > Regional Sections > USA - Texas
Old 01-08-2020, 11:39 AM   #1
dkash
Drives: 2017 camaro 2ss
Passing inspection with catted headers?
Hey guys,
I'm looking into a FBO e85 setup and would like your input/thoughts on tuners. I'm in the Houston area.
Also, I'm a little worried about being able to have the car inspected once I install (catted) headers from Texas Speed. Anyone know if once tuned, the o2 sensors read correctly and can still pass a state inspection? new to the muscle car game, excuse my ignorance.
any input would be appreciated. thanks!
dkash is offline   Reply With Quote
Old 01-08-2020, 11:58 AM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
lol wish me luck im in cali with full bolt ons and tune so well find out in 2 years or so! i passed my inspection and smog on my old car with downpipe exhaust intercooler pipiping and drop in kn filter and tune but that was a turbo car so maybe its different
Old 01-10-2020, 04:50 AM   #3
RolltideSS
RolltideSS's Avatar
Drives: 2018 SS 1LE
My 2011 had catted headers along with a big cam and still passed inspection in Harris county - as long as the tune is done properly and the car doesn’t have any issues you’ll be fine. The inspection just counts the fails or systems not ready on the ecu - you get 2 and the cats being turned off on the tune count as 1
RolltideSS is offline   Reply With Quote
Old 01-10-2020, 06:45 AM   #4
dkash
thanks for the info! exactly what I wanted to hear - thanks for the input, puts my mind at ease.
Old 01-25-2020, 02:56 AM   #5
Neil350
Drives: Nike Air Max
So long as it plugs in and can pass, you'll pass. My C6 with Long tubes, cam and catted X passed no issue. No cats they knew some thing was up but it still had the rear O2s present and passed on the plug in. I remember the last guy I took it to before I sold the car to wasn't happy about it but he couldn't fail it but he knew some thing was up.
'18 Camaro SS 1LE
'93 T/A l 398" Gen 2 LT1 l 24X l M6 l 12 Bolt 3.90 l Full suspension l Fikses
'89 T/A GTA 48K mile hard top L98 car
12 F150 5.0 Lariat Super Crew - Stock daily
Neil350 is offline   Reply With Quote
Old 02-23-2020, 12:53 AM   #6
GTO_Gregory
GTO_Gregory's Avatar
Drives: 2016 Camaro
In Bell County Texas no electronics go into the tailpipe, or get connected to the OBDII port. It's all a visual inspection. My '06 GTO has gutted Cats, so it looks fine from the outside, but they are hollow inside. I run E85, meaning the exhaust might smell different. It passed without issue.
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff.
2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85.
GTO_Gregory is offline   Reply With Quote
Old 03-21-2020, 02:47 PM   #7
jimmypop13
Drives: 2016 camaro ss
Get it tuned at the same time so you don't set codes for the rear o2 sensors. They will trigger codes since the new cats aren't as restrictive. It's a bitch to get those codes to clear so you can then tune them out. You can't just erase codes like you used to be able to. I found this out the hard way. Just get the rear o2s tuned out at the same time as the headers go in and you will be fine
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS
RIP : 2002 WS6 Black, A4, 355rwhp
jimmypop13 is offline   Reply With Quote
Old 03-25-2020, 05:59 AM   #8
Eric10905
Geezer_loves_Camaros
Drives: 2018 2SS, Black, A8
I had the same question ;-). About to start the same mods.
Anyone with experience in Travis county? (Not sure if or how the inspection criteria differs for the two counties).
TIA
Eric10905 is offline   Reply With Quote
