Old 01-05-2020, 04:40 PM   #1
dragracer582
Drives: 2013 2ss rs yellow 6spd
Rear ended ratios
Is the rear end ratio different on the 2019 zl1 1le automatic car than the 2019 zl1 automatic car?
dragracer582 is offline   Reply With Quote
Old 01-05-2020, 08:42 PM   #2
2019ZL1Droptop
2019ZL1Droptop's Avatar
Drives: 2019 ZL1
2019 ZL1 TRANSMISSION & AXLE as per GM's site.
Type:
TREMEC six-speed manual with Active Rev Match (standard)
Hydra-Matic 10-speed automatic (available)
Final Drive Ratio:
3.73 (manual)
2.85 (automatic)
Anything 1LE is broken out in the specs, so I have to assume that the ZL1 & ZL1-1LE are the same ratio. See the link provided below.
https://media.chevrolet.com/media/us...2019.tab1.html
2019 ZL1 M10 Convertible
Shadow Gray Metallic
SIGPIC][/SIGPIC]]
2019ZL1Droptop is offline   Reply With Quote
Old 01-05-2020, 08:44 PM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
same in the auto cars
Old 01-05-2020, 08:45 PM   #4
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
Like the corvettes when comparing a stingray versus a Z51 automatic cars, they have a more aggresive rear gear ratio. There should be a more aggressive rear In the 1LE automatic cars. In fact I would love to do a 3.42 gear with the 10 speed auto in any Camaro along with a non AFM converter and at least a 2500 rpm stall. Tune the trans to shift at red line in all gears when WOT and tune out torgue management.
lt4camaro is offline   Reply With Quote
