Old 01-03-2020, 10:09 AM   #1
SoulCyphyr71
Drives: 2018 Chevrolet Camaro RS
Overkill Tuning my V6
Problem was on my end. Please delete this thread.
SoulCyphyr71 is offline   Reply With Quote
Old 01-03-2020, 10:49 AM   #2
wookwook
wookwook's Avatar
Drives: 18 Camaro LS M6
you might have to let it run a couple cycles if you tripped the TCM bus. This happens if you
don't press the start button until the car goes into pre-start mode, like turning the key to "on" but don't start the engine.
get in, close everything. press the start button until the gauges and lights come on, if in an M6, basically don't push the clutch in. in A8 its probably different check your manual. Send the tune.
press the start button to shut everything off. take a couple of deep breaths. Start the car.
rinse and repeat as necessary.
as to file size you only send the calibration changes, not the whole file.
wookwook is offline   Reply With Quote
Old 01-03-2020, 10:50 AM   #3
SoulCyphyr71
Yeah, the problem was me. I didn't fully engage the instrument cluster before flashing. Thank you very much though for the information.
Old 01-03-2020, 10:52 AM   #4
wookwook
wookwook's Avatar
no prob. it will probably be saved for others. that's the purpose of a public forum.
