Old 01-02-2020, 05:02 PM   #1
floridanick
Drives: Chevrolet Camaro 2SS
2019 2SS Constant 12v dash cam/ overhead schematic
Well I attempted to find a 12v constant based off of a thread on here for 12v constant power being available in the overhead ABS connector location but I popped it open and had different colors so I downloaded the acdelco tech documents today and will investigate this weekend about trying to wire up a 12v constant power source.
If anyone knows if this is a dead end chime in before I give it another go. Really not wanting to run 12v from trunk or engine bay if I dont have to so any help is greatly appreciated.
floridanick is offline   Reply With Quote
Old 01-03-2020, 08:29 PM   #2
AzulBlaze
Drives: 2019 1SS 1LE
Ironically enough, GM decided to drop the Homelink option on the 2019+ Camaros -- which is where you can tap the harness (Red) for 12V constant for the earlier model years. If your 2SS has that rear view mirror camera, it should have a constant power source, but whether or not it's 12V, someone will have to chime in.
AzulBlaze is offline   Reply With Quote
Old 01-03-2020, 08:32 PM   #3
floridanick
Thank you for that I know they lost the home link but was under the impression power was coming from the airbag harness. No one has confirmed or denied yet so I’m stuck
Old 01-03-2020, 08:50 PM   #4
AzulBlaze
I'm not sure if you have seen this post by Gen5DIY, but it looks like they have confirmed the rear view mirror at least can provide 12V.
https://www.camaro6.com/forums/showp...1&postcount=18
You may want to drop a PM to them to see if they can confirm if it's constant or switched, otherwise grab a multimeter and do some probing on that mirror's harness.
Old 11-28-2024, 01:44 PM   #5
SladeX
Drives: Chevy Corvette Z06, Camaro 2SS 1LE
Just want to update this thread for future reference. The mirror purple/white wire is a 12V ignition wire. (Switched 12V, not retained accessory power)
SladeX is offline   Reply With Quote
