Old 01-01-2020, 08:19 AM   #1
zepol9
Drives: 2016 Camaro 2SS NGM
The Bat. A Whipple Build.
2016 SS Camaro NFG
Whipple 2.9 , LT4 HPFP , LT4 injectors, Manley pistons, Manley connecting rods,
Roto fab Big Gulp, Dsx aux fuel pump, E-85, BTR stage 2 cam kit, FTI torque converter 3200 stall. 3.625 upper pulley. pistons, connecting rods and crank being balanced.
Can anyone comment on what other things I need or any input on things I should add before buttoning her back up.
zepol9 is offline   Reply With Quote
Old 01-01-2020, 08:58 AM   #2
L78toLT1
L78toLT1's Avatar
I'd throw in some ARP main studs & head bolts.
Baby Blue
Old 01-01-2020, 09:16 AM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
ls3 front crank seal.
Old 01-01-2020, 09:29 AM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Bigger throttle body
Old 01-01-2020, 09:50 AM   #5
Johnny6.1
Drives: Camaro 1SS 1LE
Headers. From my readings the exhaust manifold and stock cats tend to b a choke point
Johnny6.1 is offline   Reply With Quote
Old 01-01-2020, 10:38 AM   #6
KingLT1
KingLT1's Avatar
Stock headers are fine. The primary cat pipes are the choke point.
Old 01-01-2020, 11:26 AM   #7
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
From which boost / power levels do the Primary CAT pipes pose a serious restriction?
Old 01-01-2020, 11:56 AM   #8
Goohead
Horsepower whisperer
Drives: Camaro
Smaller pulley
Goohead is offline   Reply With Quote
Old 01-01-2020, 03:54 PM   #9
KingLT1
KingLT1's Avatar
There was a member here that had stock headers with NEP cat deletes running 8psi. It made around 620whp. He went to LTH and gained 19whp. So imo the stock headers with cat deletes are not hurting much for power with most average boost builds. You would likely need to do rods, pistons, and turn the boost up before they pose being a big restriction.
Side note, Laynlo went 10.0 on bone stock exhaust with cats @ 14 psi on race gas. Toohighpsi went 9.9. So the stock exhaust isn't bad up to lets say 700whp, but the cats coming apart are what concern me and I would at least delete the primaries on anything more then 7psi or 550whp.
Old 01-02-2020, 07:14 AM   #10
htxSS
Drives: 2019 Chevrolet Camaro 2SS
Originally Posted by zepol9 View Post
2016 SS Camaro NFG
Bearings upgrade.
htxSS is offline   Reply With Quote
Old 01-03-2020, 05:25 PM   #11
Eldi Z
So all-in-all it seems feasible not to touch the stock exhaust system (even leave the complete CATs array in place), if boost levels do not exceed ~ 8 pounds and ~ 550-580 RWHP?
Old 01-03-2020, 08:03 PM   #12
Joshinator99
Moderator
Yep. But at much more than that you run the risk of nuking the primary cats as mentioned above by others. On my last pass of the year on 8-9 pounds and around ~630 WHP, my datalog said my drivers side cat temp was 1740 degrees...ouch lol.
Old 01-04-2020, 09:48 AM   #13
KingLT1
KingLT1's Avatar
Yes I believe most manufacturer base supercharger kits come in around 7-8psi and 550whp for a reason...and that reason is because you can bolt one on a bone stock car with no other mods and run it. When you start modding from there it becomes a slippery slope. LT4 fuel system and and exhaust mods(cat delete pipes or headers) should be considered as the next mods. Then Rotofab, bigger throttle body, and smaller pulley last.
Old 10-27-2020, 09:43 PM   #14
SSLOWSS
SSLOWSS
SSLOWSS's Avatar
Drives: Chevy SS 2019
ARP head studs
Foes anyone have any ARP Head stud kits?
I need the 234-4343 kit with the M8 corner studs.
Any help would be greatly appreciated. That is the only thing holding up a 900hp build getting done
Sincerely Brian
—SSLOWSS—
SSLOWSS is offline   Reply With Quote
