![]() Drives: 2019 GMC Sierra 1500 AT4 Join Date: Nov 2011
Hurst Billet Plus Short Throw Shifter
I installed this last Saturday. It took maybe 6 hours from pulling the car into the garage to putting away the last tool (this time includes a test drive and a few exhaust modifications that I needed to do to my header connection pipes). It was done on jack stands in my garage. The little spring pins were the toughest part. I had been holding off on this one since the install seemed like a PITA, but it honestly wasn't that bad. Definitely easier than headers.
This might be my single favorite mod to date - IMO the car should have come from the factory with this thing. The shifts are incredibly precise and mechanical feeling. There is a noticeable increase in effort, but even though I daily drive the car, I feel like it's well worth the trade off. To do over again, I would have done this mod immediately after getting the car (like first weekend). Highly recommend. I referenced the install guide from post 14 of this thread (https://www.camaro6.com/forums/showt...ighlight=hurst). He has color photos and factory torque recommendations. Some observations from my end: the 2 allen bolts that hold the shift lever into the housing has been replaced with hex head bolts in my 2018 (better IMO). If you have already installed headers, you may need to drop the aluminum skid plate to allow the engine and transmission to drop far enough to complete the install. I certainly had to.
Summit White 6" Lift, 37x13.50R24's |
#2 | |
![]() ![]() Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
To add to this.
I had a factory hurst short throw in my fifth gen. If was great, but this new one is much better. It reminds me of the feel of the MGW shifters for the fifth gen camaros and c6 vettes.
![]() Drives: 1SS Summit White 6 speed Join Date: Jul 2017
I've had mine for over a year and it's by far the best shifter I've had.
I got the pistol grip with HURST embroided onto it.
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
#5 | |
![]() Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
How far does the motor and tranny need to drop? I'm thinking of this mod, but I'm still exhausted from my header/exhaust install...
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
#6 | |
Those spring pins were a real trick though. 2 people makes it a lot easier. I had my dad use a feeler gauge to slide under the rubber grommet and engage the spring pins while I rotated them from underneath the car.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
Can’t wait to get this in. Maybe this weekend.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS M6 Join Date: Jun 2013
to make it shift with almost the same force as stock you can do the anti venom mod. https://www.camaro6.com/forums/showthread.php?t=566492
#9 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
I guess I'm going to have to break down and do this mod. I thought about it when I installed my GForce shaft and axles a few months ago.
Baby Blue
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
I had one question for you regarding the comment: "the 2 allen bolts that hold the shift lever into the housing has been replaced with hex head bolts in my 2018." Are you referring to these bolts in the picture below? The stock bolts had an external head design, whereas the Hurst supplied bolts were internal hex. Like I mentioned in my post, the internal hex bolts started to deform at the factory torque spec, so that's a step in the right direction if they changed it to the factory style external hex head bolts. I only see this being an issue for me if I ever needed to remove and reinstall those bolts for whatever reason. Did the external hex head bolts also have the beveled countersink feature or did they include a beveled washer? Otherwise I think they would have had to change the housing to remove the countersink bevel to accommodate the stock style bolt.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
#11 |
Im really surprised how many of you guys including oldman talking up the hurst considering how good the base shifter is. Im looking forward to trying it
#12 |
there is also a reverse spring https://www.ebay.com/itm/Soft-Revers...53.m1438.l2649
#13 |
Really liking this shifter.
Edit: wish I did it sooner. It’s pretty sweet. I bought both sticks and running the oem knob right now but will change sometime in the spring to the ball.
#14 |
Best mod ever
