Old 12-29-2019, 08:38 PM   #1
Markoz28
Drives: 18 ZL1 nightfall grey A10
Questions about Cordes expansion tank
For anyone that has installed the Cordes expansion tank in the engine bay, how do you like it?
How was the fit?
I heard that the rain diverter needs to be removed but can it be trimmed and still used? I was my car every 2 weeks and dont want to do rinseless/waterless.
Any complications with the system such as bleeding air out? Does it help with bleeding?
Is the capacity a noticeable benefit?
Any recommendations for somethings else if this is not ideal?
Markoz28 is offline   Reply With Quote
Old 12-30-2019, 06:11 AM   #2
jvandy50
Drives: 18 ZL1-1LE, 10 JKU
Have you considered the plastic option? I was going to avoid it because it looks like it could be in a position to get too hot, but a home brew heat shield might do the trick.
The cordes does look mich better IMO
jvandy50 is offline   Reply With Quote
Old 12-30-2019, 06:50 AM   #3
Markoz28
I’ve thought about the edelbrock reservoir but the cordes holds a bit more capacity. I don’t want to do a trunk tank since the car will be at the track maybe 4 times a year.
Old 12-30-2019, 12:37 PM   #4
kwav8r
Flyin NOE
Drives: 2018 ZL1 (A10)
I've got the Cordes tank in mine. It does solve the issue of being able to purge the system of air without having to use a special or makeshift tool.
You do have to remove the rain diverter but that can be easily modified to allow room for the tank- I've marked mine but haven't cut it as I don't drive in the rain and I use waterless wash stuff. You only need to remove a corner of the rain diverter, it's not much.
As for the capacity providing any benefit - think it would be difficult to either measure or prove/disprove. Logic would dictate that it provides a little benefit (may take a little longer to heat soak) but, again, difficult to prove.
I decided to go this route because my catch can mounts in the same location that the plastic version would and the Cordes tank frankly looks better, IMHO.
Old 12-30-2019, 02:50 PM   #5
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
This one is another good option:
http://big3racing.com/big-3-racing-6...xchanger-tank/
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 12-30-2019, 02:58 PM   #6
Markoz28
Originally Posted by JonDaddy82 View Post
I’ve looked at that one as well but have your to see any comments about it. If anyone has tried it, I’m all ears.
Old 04-05-2020, 09:26 PM   #7
Zigg L1
Zigg L1's Avatar
Drives: 2018 ZL1 Garnet Red Tintcoat A10
Bump! Looking at an expansion tank . Cordes or the big3? I do have the strut tower brace not sure if the big3 racing tank would clear that? Any thoughts or real time experiences??
Zigg L1 is offline   Reply With Quote
Old 04-06-2020, 03:21 PM   #8
Markoz28
My Cordes tank is mounted in the front by the radiator. So far so good. I’ve never used it myself to purge but the shop that did my build used it and said it worked great. It does add capacity but not really a bunch.
Old 04-06-2020, 04:51 PM   #9
MRLZL1LE
MRLZL1LE's Avatar
Drives: 2018 Chevrolet Camaro ZL1 1LE 6MT
i hear nothing but good things about Cordes and their expansion tanks. Their used on most big builds. Call Joe and he'll walk you through any questions.
2018 ZL1-1LE
Rotofab, Ported TB, 2.3 Pulley, ATI balancer w DSX 9.06 Lower ring, LME heads, 2" Kooks, custom cam, DOD Delete, Cordes Low side fuel system, Flex Fuel Kit, MM Catch can, ZL1 addons tow hook, ZL1 addons rock gaurds, Diode dynamics blacked out side markers
MRLZL1LE is offline   Reply With Quote
Old 04-06-2020, 06:32 PM   #10
Zigg L1
Zigg L1's Avatar
While is Joe?? Joe Cordes?? They are the more popular choice I am definitely gonna get something and maybe get rid of that ugly white plastic thing under the hood while I am at it
Old 04-06-2020, 06:48 PM   #11
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
CRP is very respected, I know a lot of top shops installing his tanks (as well as many other things). They're good units. As said, they'll be able to answer any questions with ease.
