Old 12-28-2019, 10:19 AM   #1
goatjacket
Drives: 2018 ZL1 (sold: 2015, Z/28; 19 1LE)
Diff fluid change proof positive
Purchased my car with 3,400 miles last week and had no verification that Diff was changed out around 1,500 as so many suggest. Figured it was worth the $50 bucks in fluid to check it out. Sure enough, that stuff was nasty. You can see the smear I pulled off sitting to the left of the plug. Am I correct this is probably the initial fluid change? Not sure how quick this stuff turns dark. The gunk on the drain plug was pretty thick sludge. I was also surprised no fluid came out of the fill port, perhaps it wasn't topped off as much as people say. Regardless I used some extra to flush it out and nice fresh fluid in and I feel more confident in my own maintenance history going forward. Thanks to the previous posts on this subject. Really is useful for DIY.
goatjacket is offline   Reply With Quote
Old 12-28-2019, 10:21 AM   #2
ZRacerLE
ZRacerLE's Avatar
Drives: The DSSV Twins: ZR2 and ZLE A10
Great info. Thank you.
ZRacerLE is offline   Reply With Quote
Old 12-28-2019, 11:16 AM   #3
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
Drives: 2019 /2SS LT1
Wat replacement fluid..is it the same for the 2020 ss?
2019/LT1 2SS
RLNTLSS is offline   Reply With Quote
Old 12-28-2019, 04:51 PM   #4
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
Warrior102 is offline   Reply With Quote
Old 12-28-2019, 06:27 PM   #5
TWG1
TWG1
Drives: 2019 Camaro ZLE
I just did my second change this afternoon. I had dealer do it at 500 miles, and today was 1500 miles, so only 1000 miles on diff fluid. I did not take photos, but my fluid was dark and both plugs had a healthy smear on them, exactly like yours. I think I’m just going to get in the habit of doing it with my oil changes.
I also looked into the pumpkin as much as I could see through the fill/drain ports. Lots going on in there - this isn’t anything like the old 12-bolt’s of days gone by. Actually looked a lot like some motorcycle wet clutches I’ve worked on. (Read: $$$$ to replace; which is why I’m going to do these services more than called for.)
TWG1 is offline   Reply With Quote
Old 12-28-2019, 06:29 PM   #6
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
I did mine at 2k I think, LOL
I do plan on doing it again after the holidays.
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 12-28-2019, 06:43 PM   #7
JROC
Drives: 19 Camaro SS 1LE, 03 Ford Lightning
I did mine around 2,400 miles and I think my drain/fill plugs looked worse than yours. Do these rearends get to a point where they stop leaving silver gunk all over the magnets every 1,000 miles or so? You would think they'd eventually get broken in good and stop flaking metal off so much into the diff fluid.
JROC is offline   Reply With Quote
Old 12-28-2019, 08:12 PM   #8
Alain
Alain's Avatar
I thought there were clutch packs in the e diff. And not metal gears. Not sure where the metal debris would be coming from.
2018 ZL1 1LE/Red hot
Old 12-28-2019, 08:22 PM   #9
breakskeet
Kevin
breakskeet's Avatar
Drives: 2018 Callaway Camaro ZL1 1LE
There are still gears in the differential. The clutches are part of the limited slip.
breakskeet is offline   Reply With Quote
Old 12-28-2019, 08:41 PM   #10
Chris357
Chris357's Avatar
Drives: 2018 ZL1 Garnet Red A10
Looks exactly like mine did in almost exact same situation. Purchased with 3400 miles assumed diff had never been changed.
2018 ZL1 Red Hot A10 (SOLD 1/21)
2001 Corvette Z06 Quicksilver Heads/Cam/Longtubes 443rwhp (SOLD 5/23)
2018 ZL1 Garnet Red A10 (SOLD 4/25)
2003 Corvette Z06 Torch Red bone stock 60k mi
Chris357 is offline   Reply With Quote
Old 12-28-2019, 08:55 PM   #11
minn19
minn19's Avatar
Drives: 22 ZL1, 20 Taco, 20 Cayenne S
I did mine at 500 and 1900 miles. I was kind of poo pooing the need for the second change, but it is cheap and easy to do. Glad I listened to people here and did it. It wasn’t as bad as the first one, but definitely didn’t look great. Agreed with others here that I’ll add it to a semi regular service. Maybe not every oil change, but every other.
minn19 is offline   Reply With Quote
Old 12-28-2019, 09:36 PM   #12
ProjectZL1
ProjectZL1's Avatar
Drives: 2017 Camaro ZL1
EXACTLY HOW I DO IT, WE EVEN USING THE SAME DRAIN PAN!
ProjectZL1 is offline   Reply With Quote
Old 12-29-2019, 07:39 AM   #13
goatjacket
I certainly appreciated your video. And you're right, GM is proud of the product. I got off fairly easy as I had some GM rewards to use, which paid for one of the quarts. Next time I'll go through Amazon as others have suggested. I typically am for trying alternatives to fluids, but agree whole heartily with the consensus that a 70K car shouldn't be 'nickel and dimed' with cheaper fluids.
I may schedule myself to change it out again in 1,500 miles (which for me will probably be summer), just to see how quickly this stuff goes bad.
Old 12-29-2019, 07:59 AM   #14
puppykat33
puppykat33's Avatar
Drives: Black 2019 ZL1 M6,
https://www.gmpartsnow.com/oem-parts/gm-oil-88862624
17 bucks per quart and cheap shipping. its 25/q on amazon..
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
puppykat33 is offline   Reply With Quote
