Old 12-26-2019, 07:55 PM   #1
Midblues
Drives: Chevy Camaro 2019 Turbo 4 LT 6sp
Rear Diff question
Hello
I have a 2019 2.0 turbo LT with 6 speed manual.I am changing the fluid and I know it has a limited slip rear diff dealer says I dont need the limited slip additive and he does not sell it. ( I dont think he knew what he was talking about) I have had a few limited Slip rears and always added the LS additive. So my question is do I need the additive and does the dealer sell it?
Any body have a part # or pic of it. I am fine using OEM fluids in rear diff.
Midblues is offline   Reply With Quote
Old 12-26-2019, 08:45 PM   #2
turbojeep95
turbojeep95's Avatar
Drives: 17 Camaro lt, 22 Camaro LT1
You do need the additive or else your tires will chirp and the rear diff will groan around turns. I bought the fluid with friction modifier in it for mine but still needed more. I used most of another tube of friction modifier before my rear diff stopped groaning.
turbojeep95 is offline   Reply With Quote
Old 12-26-2019, 09:37 PM   #3
wookwook
wookwook's Avatar
Drives: 18 Camaro LS M6
I figure my diff will stop groaning and I still have healthy skid marks. Hasn't anyone just rode it out till it finished breaking in? Actually its my first winter, and it seems like it stopped after a couple months.
wookwook is offline   Reply With Quote
Old 01-23-2020, 09:35 AM   #4
sadpanda
Drives: 2014 ATS 2.0T 6MT
Probably DEXRON LS Gear 75W-90 which includes slip addirive.
Or any 'LS' labeled fluid (ie penzoil) of same weight should be fine. I think diff MFG recommended Texaco. I would go with full synthetic regardless.
sadpanda is offline   Reply With Quote
Old 01-23-2020, 11:39 AM   #5
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
Yes, you need to flush it several times and add the additive.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, RPI Designs SS 1LE Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 02-13-2020, 12:19 AM   #6
protovack
Drives: 2019 2LT 2.0T M6 Riverside Blue
the recommended fluid is
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Dexron "LS" for limited slip, additive is already in it.
protovack is offline   Reply With Quote
Old 02-13-2020, 04:59 PM   #7
Midblues
Thanks guys will do it with next oil change
Old 02-13-2020, 05:31 PM   #8
wookwook
wookwook's Avatar
Thanks for the info, how many of those bottles would it use?
NFG M6 2T
Mishimoto Hot side pie | ZZP Catted DP | KN Drop in | Borla - Sport Tour | Apex Arc 8 - square | Wookster Tuning+ | Flex Fuel
Last PB
4.8, 13.2@106
