Old 12-24-2019, 04:29 PM   #1
Mark jones
Drives: Camaro
6th gen jacking
Any of you use a scissor jack on the pinch weld?q
Mark jones is offline   Reply With Quote
Old 12-25-2019, 04:50 AM   #2
Soleil
Soleil's Avatar
https://youtu.be/umDr0mPuyQc
Ohhhhh no way. I use only hydraulic jacks with jack pads.
Soleil
Old 12-25-2019, 08:08 AM   #3
Zaqwert6
Zaqwert6's Avatar
Drives: 2SS
I don't see why not if you can actually get it on the pinch weld. I'd just be sure to be on level ground with good wheel chocks.
Zaqwert6 is offline   Reply With Quote
Old 12-25-2019, 12:14 PM   #4
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
I use either my floor jack or my quick jack if I want the whole car in the air along with 3 jack pads on each side but would never use a scissor jack due to stability, now if I just want one side up I will jack up the car using the second jack pad from the front then use my hydraulic jack stands on the very front and back jack pads.
warren3537 is offline   Reply With Quote
