Old 12-21-2019, 09:31 AM   #1
Tampabucs4
Tampabucs4's Avatar
Drives: 2018 blue ZL1
2018 Zl1 Boost bypass mod
Anyone have results and easy instructions to adjust the valve ?
Tampabucs4 is offline   Reply With Quote
Old 12-21-2019, 10:02 AM   #2
ProjectZL1
ProjectZL1's Avatar
Drives: 2017 Camaro ZL1
I have never heard of seen of anyone doing this on these cars. Interesting to hear from anyone that has.
ProjectZL1 is offline   Reply With Quote
Old 12-21-2019, 10:36 AM   #3
FoundNemo
Drives: 2019 ZL1
It's pretty easy. Get the right bit to fit the screw, put a light behind the screw/plate it contacts so you can see when it first touches the plate.
Rotate counter clockwise until you can see a light gap between the screw and plate. Then, clockwise to tighten back until it barely touches the plate and no light is shining between. Then give it a 1/4-1/3 turn additional clockwise to lightly preload and you're set. Easy as pie.
FoundNemo is offline   Reply With Quote
Old 12-21-2019, 10:54 AM   #4
Tampabucs4
Tampabucs4's Avatar
Did you see any results like some people say 1lb to 1.5lb boost
Old 12-21-2019, 05:10 PM   #5
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
There was a thread on here way back when I had just bought my 17. So its out there, and I did it on my 17.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 12-21-2019, 09:19 PM   #6
IneedAZ
IneedAZ's Avatar
And, did you notice an improvement?
Old 12-22-2019, 01:04 AM   #7
Biscuit.fr
Drives: Red hot ZL1 A10 2017
Did that last year when it came in front of the scene....
No difference
Same psi on the gauge
Same boost
But
Mine was already with the good setting
When I checked the screw.
(TPW 04/03/17)
Heard that some folks had to do ~3/4 turns or more to match the perfect position and they felt some difference....
It doesn’t cost anything ;-)
Don’t forget to put some blue glue to fix the screw like the OEM set up.
Biscuit.fr is offline   Reply With Quote
