Old 12-18-2019, 08:19 PM   #1
abbadon3718
abbadon3718's Avatar
Drives: 2017 2SS
Lt5 ported TB throwing code
I recently purchased a pray ported lt5 TB from a forum member. I knew it would require a tune but I had read several members that ran a ported TB for a while before getting their tune without issue. When I installed though I got the p2101 reduced engine power, which immediately cleared up after putting the stock TB back on. My question is has anyone else ran into this issue just because the ecu isn’t happy until tuned or was I sent a defective part? I think the posts I read were from ported 87mm TB, this is obviously larger since it started life as a 95mm. Thanks for your help.
abbadon3718 is offline   Reply With Quote
Old 12-19-2019, 12:55 AM   #2
kingwale
Drives: 2017 SS
I’ll buy it!
kingwale is offline   Reply With Quote
Old 12-22-2019, 03:54 PM   #3
TurboVet
Drives: Corvette
Your intake must be ported so the throttle body can open up all the way.
TurboVet is offline   Reply With Quote
Old 12-22-2019, 07:27 PM   #4
abbadon3718
Drives: 2017 2SS
Thanks for your help man, much appreciated.
Old 12-23-2019, 01:07 AM   #5
blueg1
blueg1's Avatar
Drives: 2016 camaro ss
You can also buy an adapter that will allow it the clearance to open all the way.
blueg1 is offline   Reply With Quote
Old 12-23-2019, 01:05 PM   #6
RobbyBeefcake87
RobbyBeefcake87's Avatar
Drives: 2018 Camaro SS 1LE
I've heard ported 87s and stock 95s can be run on the stock tune from what I hear, but I've never heard the ported 95 being 100% ok without a tune, this would be news to me.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler.
2018 Colorado zr2 - zr2 sport bar, showcase spare tire.
2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace.
2017 Corvette Grandsport (sold) - untouched.
2006 GTO (sold) - iat relocation, air box mod, monero side marker lights.
RobbyBeefcake87 is offline   Reply With Quote
Old 12-23-2019, 07:33 PM   #7
Dixie ZL1
NOXQCES ZL1
Drives: 2017 Camaro ZL1
The adaptor won’t allow it to open, it only adapts the bolt pattern. The intake or blower snout must be ported to accommodate a 95mm TB.
Dixie ZL1 is offline   Reply With Quote
Old 12-23-2019, 07:43 PM   #8
Dixie ZL1
NOXQCES ZL1
The 95mm TB (ported or not) willl require a tune to take advantage of it. The LT5 TB uses a significantly difference scalar (throttle response from the ECU) than the stock 87mm
