Old 12-17-2019, 10:00 PM   #1
teddyca
teddyca's Avatar
Drives: Blown C7 and 6th gen
Changed oil and car took 11 quarts?
Got me baffled. I literally drained every oz (not really) out of this pig. Jacked on the driver side and let it drain for about 30 min. Filled it with 10 quarts and it didn't even read on the dip stick?? Put in an 11th quart and it is now about 3/4 up the fill line on the dip stick. I even started it to get the damn car to settle. Now I am concerned.
By the way I made a fricking mess. I am over oil changes hahaha
14 Corvette Z51 Coupe - 655RWHP
A&A Ti Blower, Alky Control Meth kit, Kooks LT setup, Corsa Catback, Full APR CF kit, RK Sports CF hood, hell CF everything LOL
17 Camaro 2SS 50th edition. TOTALED 6/2019
K&N Intake, MRBP axleback, Eibach kit, 20" Z28 wheels, smoked lights all the way around, Rockford Fosgate system
17 Camaro 2SS 50th edition. Round 2- 8/2019 550/600 RWHP, Magnuson TVS2300, Rotofab Intake, Corsa Xtreme, Air Lift P3 System, 20" Stance SF-07, smoked lights all the way around, Rockford Fosgate system.
teddyca is offline   Reply With Quote
Old 12-17-2019, 10:25 PM   #2
closs2sx
closs2sx's Avatar
Drives: 1970 chevelle
Both mine took 11 as well but I let them drain for a long while.
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car
2015 Z06 Z07
Daytona Sunrise Orange Metallic
Dads Car
2013 ZL1 vin 963
Crystal Red Tint Coat/Black Wheels
Exposed Carbon Fiber Insert
6 Spd Manual
closs2sx is offline   Reply With Quote
Old 12-17-2019, 10:40 PM   #3
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
You use a New Dry oil filter?
Old 12-17-2019, 10:47 PM   #4
Mountain
Mountain's Avatar
When I had my 2016 1SS, and changed the oil, about 10 qts came out and about 10 qts went in.
With my 2017 SS 1LE, the first change I did, I ended up putting in almost 11 qts. After driving the car, I found it over-full according to the dip stick and drained some out. Did some reading of others putting in 11 qts and some people talked about MRC cars not fully setting after being lifted and effecting the oil level reading - some people say it's a thing and some people say it's "BS". Well, my subsequent oil changes after that first one I made sure the suspension gets settled fully (I roll/drive the car forward and back) and I end up putting in a bit more than 10 qts (something like 10.25 qts).
Maybe there was a change in the dip stick [design]? Dip sticks aren't 100% accurate, but should be fairly close.
I've never ran into something like this in any of my past vehicles. Maybe my "letting the car settle" is BS, but it seems to work, so...
Old 12-18-2019, 12:46 AM   #5
c4racer
Drives: 2016 SS Convertible
Capacity is 10qts with the filter. Go with that. Check it after several hours or the next day even.
c4racer is offline   Reply With Quote
Old 12-18-2019, 12:52 AM   #6
closs2sx
closs2sx's Avatar
I’ll have to check mine in the spring but on both my zl1 1le and my ss 1le I added the oil while on my Mohawk two post lift which is level I started them after I added 10 and ran the car in 1st gear slowly to get the rear and tranny to move the fluids around as I do them as well then I shut the car off topped off the trans and diff checked the oil and saw that I needed to add so I took the cars off the lift then moved them to their spot in garage and checked them an hour or so later and they still needed some with the dipstick all the way in. On my z06 it calls for 9.8 and I put 10 in and follow the required procedure and it’s good
I didn’t need the full 11 but it was at least 10.5 but I don’t use the regular pf64 filter maybe that’s the difference because both cars used roughly the same amount and I used the same filter on both but I used the 0-40 Mobil on the zl1 1le and I used 5-30 driven oil on the ss 1le as recommended by vengeance racing as they did the build on the car
MY Car
2015 Z06 Z07
Dads Car
2013 ZL1 vin 963
6 Spd Manual
Old 12-18-2019, 07:24 AM   #7
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
10 quarts with filter change. No more no less! States it in the owners manual. That’s what I put in my 2016 SS and now in the ZL1.
Old 12-18-2019, 08:29 AM   #8
Abubaca
Abubaca's Avatar
Drives: 2016 SS
My auto shop teacher back in HS used to tell us he'd check the oil level after a change to make sure he didn't have TOO MUCH oil, and to confirm he remembered to put the oil plug back in. Ironically, I HAVE forgotten to do that!!!DOH!!!!!!!!!
Abubaca is offline   Reply With Quote
Old 12-18-2019, 08:54 AM   #9
DIYguy
DIYguy's Avatar
Drives: 2017 Camaro 1LT
Red face
....and to confirm he remembered to put the oil plug back in. Ironically, I HAVE forgotten to do that!!!
Join the club.
I did that years ago on a Mustang.
Four quarts down the filler before I noticed the puddle spreading out from underneath.
Gen6 Camaro LT (my daily driver), Cruze ECO (grocery getter), Chevy SS Pickup (wife's daily driver), Honda Shadow, Honda CBX
DIYguy is offline   Reply With Quote
Old 12-18-2019, 09:52 AM   #10
JT58
Drives: Former 2016 Camaro 1LT
Having too much oil is not good either. Dip sticks may or may not be accurate. What I do is go with the manufacturer's capacity of oil with the oil filter changed. I then start the car, let it idle a minute or two, shut it off. I wait about 5-10 minutes and check it again. As long as it is in between the add and full marks I leave it. I check it again over the course of the next couple of days after it sits over night and some times it reads a little higher on the dip stick. It could be a combination of the paper filter initially absorbing more oil initially and/or letting the car sit overnight and the oil fully draining back into the pan. I don't worry too much about filling it to the maximum mark. I just know where it is in between the marks and as long as it does not get any lower in between oil changes, it's fine.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
JT58 is offline   Reply With Quote
Old 12-18-2019, 11:19 AM   #11
67rstbkt
Drives: 2016 Camaro 2SS, 1967 Firebird
I just changed the oil on my 16 2SS - 10 quarts is what came out and 10 quarts is what went in. I add oil to my new filter before I install it, add the rest to the engine, check level, then start the car, shut down, let it sit for about 10 minutes and check the oil.
67rstbkt is offline   Reply With Quote
Old 12-18-2019, 11:26 AM   #12
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Been consistently 10.5 for me, same as the manual indicates.
And hey, if you forget the plug just call it a "flush"...
Old 12-18-2019, 11:50 AM   #13
ctrlz
Push on the dipstick tube to make sure it is fully seated.
Old 12-18-2019, 01:32 PM   #14
teddyca
teddyca's Avatar
Welp when the weather sides tomorrow I will take it for a ride and check it. Not a big deal. if I have to drain a bit I will. Was just curious.
