Old 12-15-2019, 10:32 PM   #1
F419sr1
F419sr1's Avatar
Drives: 2017 ZL1
Open trailer questions
I’m searching for a open trailer. Preferably aluminum that I can load my Zl1 on without having to stack wood or any type of blocking. Anyone have suggestions on what brands to look at. Length ramp length. Just want a simple process
Kooks full exhaust, Roto Fab, Whipple,Williams 103, Fore innovation, JRE cam and tuning
F419sr1 is offline   Reply With Quote
Old 12-15-2019, 11:20 PM   #2
OVERPAR73
2018 Garnet Red ZL1 conve
OVERPAR73's Avatar
Drives: 2013 & 2018 ZL1 vert
Open trailer
I have a Aluma trailer and love it! The fenders are removable so the door opens right over the tire when getting out. The loading ramps slide out the back and are stowed underneath the trailer. As you can see it has the protection for the front and also air compressor/winch combo. Good luck.
Build Thread: 2018 ZL1 Vert Purchased (Overpar73)
OVERPAR73 is offline   Reply With Quote
Old 12-15-2019, 11:36 PM   #3
F419sr1
F419sr1's Avatar
Drives: 2017 ZL1
How long is the trailer? Are the ramps 8’? Do you have to use anything to keep the splitter from hitting? Iv rented a couple and did. I’m trying to avoid that.
Old 12-16-2019, 12:02 AM   #4
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
https://www.futuratrailers.com/
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 12-16-2019, 12:49 PM   #5
kaamacat
Drives: 2018 ZL1/1LE Red
I have an Aluma8220 which tilts (love it!) but still have to place some very small rubber mats before the trailer to 100% clear, getting my tires ~1.5" higher. The Futura is probably the only one out there as a flat drive-on, but, much more costly. (I bought a TractorSupply stall mat which is a dense rubber and about 3.4" thick. Cut it into 1' squares for many uses, including my "lego style" mini ramp use)
BobR
2018 ZL1 1LE (Red) - New Dec 2017
2015 ViperGT (Gunmetal w/Red stripes)
2013 ZR1 Anniversary
2014 ZL1 - BrightYellow, 6sp
2011 Porsche GT3RS - White w/red graphics
2009 Porsche C2S
2001 Ferrari 360
kaamacat is offline   Reply With Quote
Old 12-16-2019, 12:55 PM   #6
Nrfd79
Drives: 2018 ZL1 1LE
I use a Maxey Drop-n-Load .
Works really well
Nrfd79 is offline   Reply With Quote
Old 12-16-2019, 03:12 PM   #7
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
+1 futura. I love mine
Timbo-1LE is offline   Reply With Quote
Old 12-16-2019, 03:33 PM   #8
laynlo15
Drives: 2022 Lt1 A10
Here is my 20' Sundowner, removable fenders, tows awesome behind my 17 GMC 6.2. Easy to load and tie down, plenty of room up front for another box. The smaller box comes standard and also comes with side mounted spare
Old 12-16-2019, 03:46 PM   #9
laynlo15
Couple more pics for you. This trailer listed for 7k. Worth every penny and would never pull a steel trailer again. Traded my enclosed trailer back in for this one.
My ramps are 7 feet long, they slide in the rear and easy loading of my lowered Camaro. It also has torsion axle/springs and not leaf so that's how they get it to sit so low.
Old 12-16-2019, 03:53 PM   #10
Badmojo
aka BeastZL1
Badmojo's Avatar
I've got the Aluma 8218 Tilt and it works well. I do use some small MDF boards to load. It is going to be tough to find something that needs nothing due to the limited clearance so far ahead of the front wheels.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 12-16-2019, 04:59 PM   #11
F419sr1
F419sr1's Avatar
Drives: 2017 ZL1
Attachment 1013578
Attachment 1013579
Iv watched some videos on this trailer. They say it’s lower than others but don’t say how much. Your car goes on without any blocking?
Old 12-16-2019, 06:17 PM   #12
laynlo15
Yep, my Camaro is 1.5 inches lower then stock. Steel trailers I've had in the past had didn't work for my car and had to use 2x10s to put under the ends of the ramps to make the 6ft steel ramps work. Never again. Low and go for sure. You'll love it if you buy one and those cool vids Sundowner does on the website its very helpful. Its at least 4-5 inches lower then a standard steel trailer. Here is my old steel trailer and it was a pretty nice one but you can see the height difference.
Old 12-16-2019, 06:26 PM   #13
most-wanted
Drives: ZL1
sundowner has about the nicest trailer you can buy. I have had Aluma, Featherlite, Sundowner etc. The Sundowner towed the nicest etc. Just make sure you get one with 8' ramps as some come with 6'. I bought the sundowner with front storage. Best trailer Ive ever owned.
most-wanted is offline   Reply With Quote
Old 12-16-2019, 06:33 PM   #14
most-wanted
Drives: ZL1
Here was mine. Cant go wrong with this trailer.
