Old 12-15-2019, 01:14 PM   #1
puppykat33
puppykat33's Avatar
Drives: Black 2019 ZL1 M6,
Take a Look at this black magic Whaaaat
I just ran across this watching a borla install. Its called valvomax. Its the first time i have seen it, maby i am just behind the times but definitely looks worth looking into.What does all of my ZL1 peeps think? looks like a hella good idea to me...
https://www.valvomax.com/products/va...nt=21023681733
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
puppykat33 is offline   Reply With Quote
Old 12-15-2019, 01:27 PM   #2
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I don’t know but it might be easier than the factory drain plug! The only problem I have is getting the front end high enough to change the oil therefore I will order some Race Ramps from Summit Racing in the near future!
Old 12-15-2019, 01:33 PM   #3
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Some of the heavy equipment we purchase come equipped with plugs like that. We call them environmental plugs. Makes for a much cleaner oil change experience especially on windy days.
Old 12-15-2019, 01:40 PM   #4
puppykat33
puppykat33's Avatar
yea LT4greg gotta have the race ramps its almost a must to do it quickly i figure they pay for themselves after the first few oil changes or so. Yes it will definitely tame the 10q spray when draining the oil. plus you can do it while the oil is warm. I found a youtube of a guy with a camaro who put one in and used it.. No mess no drips.
Old 12-15-2019, 01:52 PM   #5
PROMETHEUS
PROMETHEUS's Avatar
Have something similar, Stahlbus Oil Drain Valves.
Stahlbus oil drain valves are installed in place of conventional oil drain plugs. Once installed the valves simplify the procedure for changing oil in your car. The quick disconnect drain hose connector snaps into place opening the valve to drain the oil. When the drain hose connector is removed the valve automatically closes. Each Stahlbus oil drain valve includes a high-strength steel valve body, copper sealing washer, anodized aluminum safety cap, quick disconnect hose connector, 40 cm Silicone drain hose, and instructions.
Unlike competitive oil drain valves, Stahlbus oil drain valves do not have a lever-operated ball valve. The absence of a lever allows for a much smaller valve design compared to competing products. The Stahlbus drain valve is just slightly larger than the standard oil drain plug. The smaller symmetrical shape of the Stahlbus valve allows it to be installed without an additional adapter frequently required by the more bulky lever-operated valves.
The Stahlbus oil drain valves are precision made in Germany.
http://www.stahlbus.com/products/en/oil-drain-valve/
Carried by a number of vendors to include Amazon.
Makes changing oil..alot less messy!
Old 12-15-2019, 01:54 PM   #6
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
Ooooh this looks nice. I have a lift and it's still a bitch to catch all 10 quarts with zero splatter when warm. I run a fumoto valve on my truck since it sees a LOT of oil changes.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 12-15-2019, 08:53 PM   #7
puppykat33
puppykat33's Avatar
well see i told you i was just behind the times.. yea prometheus i think they copied the stahlbus
Old 12-15-2019, 09:12 PM   #8
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
+1 on the Stahlbus valve. I have one on my car.
Makes taking samples for Blackstone a breeze.
Old 12-16-2019, 07:06 AM   #9
Gary H
Drives: Camaro ZL1
What's the correct size for the Zl1 please guys?
Made in the USA. Refined in Great Britain - insta: zl1uk
Velossa intake, Rotofab, Mamo TB, Custom ported NX Lid & Jokerz Full tilt ported LT4 charger, 3 port CoolingMist Meth injection - ATI 15% lower pulley, E2X CC, TSP ceramic coated longtubes, de-cat and Borla 60608 to NPP box, JRE tune, BMR rear control & trailing arms, lock-out kit, lowering springs and front strut brace, Custom carbon trim interior, Xpel ultimate front PPF and Prestige window tint with Chameleon Windscreen tint...ever evolving...
Gary H is offline   Reply With Quote
Old 12-16-2019, 09:55 AM   #10
Vigilante375
Drives: 2018 Camaro ZL1
M12-1.75
Old 12-16-2019, 10:22 AM   #11
viurniel
@viurniel
viurniel's Avatar
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT
+1 Stahlbus
viurniel is offline   Reply With Quote
Old 12-16-2019, 10:54 AM   #12
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
I use the Stahlbus, best thing ever for maintenance.
https://www.amazon.com/Stahlbus-Drai.../dp/B01AMXATSC
Old 12-16-2019, 08:41 PM   #13
Marty31
Marty31's Avatar
Drives: 2019 ZL1 A10
Great thread guys. I just ordered Stahlbus. I picked up some Race Ramps this past fall and will enjoy doing a lot of my own maintenance now.
Marty31 is offline   Reply With Quote
Old 12-16-2019, 09:48 PM   #14
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Only thing that could make oil change easier on this car is if oil filter was on top like many euro cars and you could remove oil w suction setup - no ramps required.. but its not. Drain is clean, no cross members in way, nice smooth drain. Filter is almost, easy to rectify w few holes in the filter body to allow it to drain and minimize "spill".
I would not add any points of failure in such critical area.
ing for grip.
http://www.motorsportsne.com/
