Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Exterior Parts & Accessories
Old 12-11-2019, 09:20 AM   #1
PFYC
PFYC's Avatar
Drives: Yes
Morimoto Custom LED Tail Lights for 2016-2018 Camaro
https://www.pfyc.com/morimoto-custom...18-camaro.html
With GM discontinuing their custom clear/dark tail lights your custom tail light choices are limited. These are a great way to change out your stock Camaro taillights and help your car stand out.
No doubt the sixth-gen Camaro is a capable car, and if you've already upped the ante by making more power, new wheels, and fatter tires, then it's time to ditch the stock lighting setup too. Morimoto's unbeatable XB LED fog lights have been top sellers in our catalog forever, and we couldn't be more excited to see the lineup expand with offerings such as the new high-performance XB Camaro LED tail lights too!
COMPATIBLE: With all 2016-2018 Camaro's, these complete tail light assemblies will swap directly in place of the original Camaro tail lights, use all of the stock mounting points, and should only take around 30 minutes to install.
PLUG N PLAY: Wiring is easy too! The XB LED tails are designed to work without any special wiring. They will plug into the factory connectors for the stock lights and each assembly includes all necessary connectors, rubber seals, and pigtails for a plug n play install. No additional resistors, modules, etc needed!
STYLE: Inspired by the Lamborghini Aventador, while they look radical, they don't look out of place like other aftermarket options. The piano black finish matches the OEM trunk trim perfectly. The geometry flows with the body lines like a boss. The XB LED tails for your Camaro are available with either a smoked or red lens. Both will illuminate red.
WELL-BUILT: Their durable polycarbonate lens will resist the test of time, keeping the housings looking new for many years to come. The injection-molded ABS housing is light-weight and much stronger than comparable cheap alternatives. The XB Tail lights may not be the cheapest new tail lights for your Camaro, but they're OE quality, and as the saying goes, you pay for what you get.
Application
2016 2017 2018 Camaro
FREE SHIPPING in the Lower 48 states! Half price shipping to Canada.
PFYC is offline   Reply With Quote
Old 02-09-2021, 03:48 AM   #2
Captnhowdy67004
Captnhowdy
Captnhowdy67004's Avatar
Drives: 2018 camaro ss/2
Send a message via Yahoo to Captnhowdy67004
Im having problems with morimoto xb led tails inspired by the 2019 camaro i hitcthe key fob unlock passenger side reverse lights comes on but not the drivers it blinks and like goes out sometimes it dont even blink anyone have this problem i have a 2018 camaro ss this is the 2nd set of tails and adapters alzo same problem always drivers side but everything else works fine turn signals llights
Captnhowdy67004 is offline   Reply With Quote
Old 10-11-2022, 01:21 AM   #3
PFYC
PFYC's Avatar
Drives: Yes
Thank You for shopping at https://www.pfyc.com/morimoto-custom...18-camaro.html
