Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Interior Parts & Accessories
Old 12-08-2019, 09:59 PM   #1
Juiced1
Drives: 2012 2SS CAMARO 45th
AutoMeter OBD2 Digital Gauge on Sale at Juiced Motorsports
Create a virtual dashboard for your vehicle using the completely redesigned AutoMeter DashLink app. Easy OBDII plug and play installation makes for the fastest performance gauge installation available. DashLink enables you to take advantage of AutoMeter’s years of instrumentation and data acquisition expertise to transform your Apple iOS or Android enabled device into a customizable display and monitoring system. AutoMeter DashLink puts you in control - Monitor and data log engine and vehicle performance, fuel economy, and instantly read and clear troublesome check engine lights, all with the easy to use plug-n-play functionality of the DashLink system. The AutoMeter DashLink is the most accurate, easiest to use vehicle display solution in the market!
Features:
  • Display - Feature the gauges you want, where you want them on your favorite iOS or Android device
  • Data Log - Record and playback log files showing OBD-II and acceleration data
  • Peak Recall - Help keep your eyes on the road or track by using the built-in recall to view the maximum values at your convenience
  • Skid Pad - Show lateral and accel/braking G's with min/max indicators
  • Rainbow Track Map - Visualize your location, acceleration and braking as you drive laps around the track. Compare different laps to see how acceleration and braking changed from lap to lap
  • Inclinometer - Monitor the pitch and roll of your vehicle for off-road use
  • Support for OBD-II diagnostics - Read and clear diagnostic trouble codes (DTCs)
  • Averages - Determine average fuel consumption, average vehicle speed, average boost pressure, or any other parameter monitored
  • Trip Computer - Maintains stats for up to 5 trips
OBDII DIGITAL GAUGE (APPLE IOS/ANDROID)
Juiced1 is offline   Reply With Quote
Old 12-18-2019, 10:51 PM   #2
Juiced1
Awesome options and affordable.
Old 12-27-2019, 09:44 PM   #3
Juiced1
Great options. Check it out
Old 01-07-2020, 09:00 PM   #4
Juiced1
OBD2
Old 01-18-2020, 08:19 PM   #5
Juiced1
Great for data logging
Old 01-19-2020, 09:10 AM   #6
Aboynamedsue
Aboynamedsue's Avatar
Drives: 2017 Camaro SS
Will this read ethanol content if you already have a sensor installed?
2017 SS manual ordered through the one and only Becky!
For sale: https://www.camaro6.com/forums/showthread.php?t=612154
Aboynamedsue is offline   Reply With Quote
Old 01-29-2020, 06:03 PM   #7
Aboynamedsue
I’m interested in this product. A response would be appreciated.
Old 01-29-2020, 08:53 PM   #8
Juiced1
Sorry, didn't see the message. Yes, it will read alcohol percentage if you have a flex fuel sensor.
Old 02-04-2020, 03:19 PM   #9
Aboynamedsue
My friend just bought one of these, and the alcohol percentage isn't showing up. Any advice? It's basically the only reason he bought it.
Old 02-06-2020, 11:57 AM   #10
Aboynamedsue
Any thoughts?
autometer, gauge, obd2
