Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Miscellaneous Items
Old 12-06-2019, 09:44 AM   #1
PFYC
PFYC's Avatar
Drives: Yes
Whats HOT Whats NEW in December at PFYC!!
Custom Build Lloyd Ultimat Floor Mats for Your 6th Gen Camaro
Custom build your Lloyd Ultimat Floor Mats or Trunk Mats using our custom configurator and get your mats built exactly the way you want them. Choose your mat color, select your logo and optional premium binding for the perfect mats for your 2016 2017 2018 Camaro.
The Ultimat is Lloyd Mats' most popular custom floor mat line and features premium continuous filament nylon yarn for durability. The yarn weight of 32 ounces per yard is twice the weight of most factory floor mats.
Application
2016 2017 2018 2019 Chevrolet Camaro
Your Lloyd Mats always ship for FREE at PFYC! Half price shipping to Canada.
Show N Go Retractable License Plate Frame
If you live in a state that requires you to have a front license plate but you don't like the look and don't want to drill holes in the front of your car.Hide your License plate by adding the Show N Go Retractable License Plate Frame. Choose between the manual or motorized. The Show N Go retractable license plate frame enhances your vehicle aesthetics. Easily installed, stainless steel and patented robust design this product fits almost any vehicle on the road.
Do not be alarmed the approximate dimensions being 10 1/2 inches long, 12 inches wide and 1 1/4 inches high gives enough room from the ground to apply to your vehicle with no problems
Application
This is a universal fit application. Click the Installation Instructions below to see how it is installed and how it might fit your specific vehicle.
FREE SHIPPING in the Lower 48 states! Half price shipping to Canada.
WeatherTech Floor Liners for 2016-2019 Gen6 Camaro Coupe
The WeatherTech FloorLiner DigitalFit accurately and completely lines the interior carpet of your new Camaro giving Absolute Interior Protection. Digital laser measurements of interior surfaces offer a consistently perfect fit. A patent pending High Density Tri-Extruded (HDTE) material allows for a rigid core for strength while offering surface friction to the carpet, as well as tactile feel to the surface. Advanced surfacing creates channels that carry fluids and debris to a lower reservoir with further channeling to help minimize fluid movement while driving!
Trust WeatherTech Floor Liners to protect your interior and make cleanup from life's adventures quick and easy.
Application
2016 2017 2018 2019 Camaro Coupe
Wheelskins Leather Steering Wheel Covers
Wheelskins are the finest, most luxurious Genuine Leather Steering Wheel Covers available. They are individually hand-crafted in California of choice domestic cowhide, especially tanned for Wheelskins. Their exclusive patented lacing hole reinforcement system ensures a tight custom fit on any steering wheel.
Easy to install, Wheelskins are the best way to inexpensively customize and upgrade any plastic steering wheel. They are also the premier option for replacing a damaged or worn original factory leather covered wheel.
Wheelskins exclusive patented lacing hole reinforcement system ensures a tight custom fit on any steering wheel. Thread and needle included. Takes about 30-60 minutes to install.
Curb Alert Front Bumper Protection System
Introducing the cure for the common curb, the Curb Alert. Front end damage when parking is a very real problem for many cars on the road today, especially for vehicles who have installed ground effects or aerodynamic profile improvements on their vehicles.
Curbs are something that are one of those road hazards that do more damage to sports cars than any other hazard on the road. In fact, just a simple trip to the corner store can become a costly errand if you over-estimate your front end clearance when parking: damage repairs could easily run $1000 or more; however, Curb Alert provides you a warning system that gives you three-deep warning tones as you approach too close to a curb.
The Curb Alert is very easy to install and does not put a drain on your battery when the car is not on. Using a patented infrared technology, the front mounted sensor is calibrated to a warning distance of anywhere from 8-28" (you decide with whatever you feel comfortable with).
The warning alarm is hidden in the car and will give you three gentle tones when you are within a specified distance to the curb. The system gives you a short beep every time you start your car to let you know the system is active. The Curb Alert is one of a kind and is a gadget that will save you money in the long run, preventing front end damage to any car that is low enough to be vulnerable to a Curb.
Do not take a chance, get the Curb Alert to prevent curb damage.
Pedal Commander Throttle Response Controller for 2016-2019 Camaro
Feel the power of your Camaro as soon as you push the pedal to the floor by adding the Pedal Commander Throttle Response Controller for 2016-2019 Camaro Eliminates Delay. Nowadays, vehicles are notorious for their delayed throttle response. That's where the Pedal Commander comes in. These days, vehicles use a drive-by-wire system that monitors the position of the gas pedal to control the throttle electronically, similar to a dimmer switch. The problem with this setup is that the signal from the pedal has to first be sent the ECU, which in turn then sends the signal to the actuator motor that controls the throttle body itself. This delay is most noticeable when trying to speed up to merge with fast moving traffic or pass a slower moving car. However, the Pedal Commander Bluetooth Throttle Response Controller will eliminate that delayed throttled response, giving your vehicle a drastic night and day difference in performance. Four Adjustable Control Modes. Unlike other throttle control devices that are either on or off, the Pedal Commander comes with 4 control modes: Eco, City, Sport and Sport +. Best of all, each mode has an additional 8 different levels of sensitivity which allows you to personally adjust each mode to your own personal driving style and needs. Switching between modes can be done manually on the Commander or can also be done using your smartphone (Pedal Commander App), without having to bend over and physically touch the Pedal Commander. Compatible with Aftermarket Programmers. The Pedal Commander can be used in conjunction with common aftermarket OBD-II programmers and/or monitors such as: SCT, Diablosport, Hypertech, Superchips, Bully Dog, and Edge. 2-Year Product Warranty. Pedal Commander manufactures their Bluetooth Throttle Response Controller to the highest quality and standards with CE and TUV Certification. However in the event you do receive a defective or malfunctioning device, Pedal Commander will replace it free of charge within 2 years of the original purchase date. Easy Plug & Play Installation. The Pedal Commander Throttle Response Controller connects directly into the stock throttle position sensor found on the drive-by-wire gas pedal using an OEM style plug and play connector with no permanent modifications required. The Pedal Commander is 100% reversible making it warranty friendly.
Application
Front Bumper Mask Bra Novigo NoviStretch for 2016-2018 Gen6 Camaro
NoviStretch StretchBra tm is a quality nylon bra designed for the front of your Camaro. The best feature is that this bra can be installed and removed within 3 minutes, making great for car show. Simply install it for the drive and remove it for the show!
There are three screws that hold the fender liner in place and we replace those screws with a snap head screw. So the mask snaps in the wheel well area and there are two plastic clips at the top of the mask that hook to the upper grill bar. That is the initial installation. Once that is done, simply snap in place to re-install or remove.
Folds up and can be stored right in your glove box!
This Camaro NoviMask product is "better than Vinyl or Leather and cheaper than Film" ; "Made in the U.S.A".; "backed by the manufacturers warranty and customer satisfaction policy".
We want to point out although the product is new to the 2016 Chevrolet Camaro market it has been successfully time-tested in the Corvette market for the last nine years.
Application
Custom Fit Car Cover for 2016-2019 Gen6 Camaro
PFYC.com offers several levels of protection and coverage for your 6th Gen Camaro. These are custom fit covers specifically designed and fitted to the shape of your Camaro. These are not generic fit covers. Below is a description of each material that should help you decide which cover is right for you.
Application
Color Matched Hood Shock Cover Set For Camaro
PFYC is pleased to offer this Color Matched Hood Shock Cover Set for your 2016-2019 Camaro. This set will be a great visual upgrade for your engine compartment that will set it apart from the rest. Professionally machined and painted, each part is made from premium aluminum billet and finished with a durable paint coat as rich and lustrous as the paint on your Chevrolet Camaro. This Hood Shock Cover Set is very easy to install and looks like parts that might have come from the factory, only much better. This GM officially licensed product is made in the U.S.A. Please choose your paint color and logo from the drop down boxes. Due to item size limits, not all logos shown are available for every item.
Application
PFYC is offline   Reply With Quote
Old 10-11-2022, 01:17 AM   #2
PFYC
PFYC's Avatar
Drives: Yes
Thank You for shopping at https://www.pfyc.com/custom-build-ll...en-camaro.html
