Old 12-04-2019, 10:04 PM   #1
Haoie
Drives: 2017 50th Anniversary SS
Strong smell coming out of the car on startup
As title says, at random times I would smell some sort of rich smell, I have some issues with my coolant and how the top tank isn't completely filled. Could the strong smell be a result of coolant leaking into a gasket?
Haoie is offline   Reply With Quote
Old 12-04-2019, 10:17 PM   #2
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
Strong smell like what, gas, oil, sweet smell?
Jaxcam02 is offline   Reply With Quote
Old 12-05-2019, 12:08 AM   #3
Haoie
It has a sweet smell to it, I would notice clear smoke coming from the exhaust whenever I would smell it too but today was just the smell
Old 12-05-2019, 12:14 AM   #4
caSStro18
Drives: 2018 Camaro SS
First need to figure where the smell is coming from. Is it coming from the exhaust? If you pop the hood can you smell it there? These cars let out some smoke on cold starts, so that’s normal.
caSStro18 is offline   Reply With Quote
Old 12-05-2019, 12:44 AM   #5
Sweet smell most likely means you have a coolant leak, I'd check the hoses and the radiator first.
Old 12-05-2019, 07:26 AM   #6
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Could be a coolant leak somewhere in the cooling system.
Old 12-05-2019, 09:06 AM   #7
pabex
pabex's Avatar
I do have some type of smell too on startup but tbh I havent payed attention on whether its sweet or what. I just assumed it was normal startup smell. Ill look out tomorrow when I start it up. all you camaro owners, do you experience any kind of smell at all during startup?
pabex is offline   Reply With Quote
Old 12-05-2019, 10:19 AM   #8
LT4Greg
LT4Greg's Avatar
Yes gas and oil smell mix on start up when it’s cold but mostly oil smell and no blue smoke out of the tailpipes. Perfectly normal!
Old 12-05-2019, 10:24 AM   #9
pabex
pabex's Avatar
gotchya, that might be it for mee too
Old 12-05-2019, 11:12 AM   #10
Justcruising
Justcruising's Avatar
Drives: 2019 Chevrolet Camaro 2SS A10
The only smell I get is the sweet smell of gas as the converters heat up, I could be wrong on that but all of my cars have smelled that way as they warm up
Justcruising is offline   Reply With Quote
Old 12-05-2019, 11:30 AM   #11
c4racer
Drives: 2016 SS Convertible
These DI V8's start up very rich so there is unburned fuel in the exhaust - especially with an extended crank period when cold which is also much more common on these cars.
all normal and all very different from previous LS motors too.
My carb motor in the 71 starts up quicker than my LT1!
c4racer is offline   Reply With Quote
Old 12-05-2019, 12:27 PM   #12
MackSteelPrivateEye
Oh Lord. Sounds like a failed head gasket. I hope its under warranty.
Old 12-05-2019, 12:29 PM   #13
MackSteelPrivateEye
Wait a sec...you say clear smoke. Is it in fact clear or is it white?
Old 12-05-2019, 01:27 PM   #14
ctrlz
Reservoir low and sweet smell. Sounds like coolant leaking onto exhaust part. Any drips under the car?
