Old 12-04-2019, 06:38 AM   #1
tlk-1997
tlk-1997's Avatar
Drives: 1997 Camaro SS LT4
Hot Wheels with Edelbrock 2650
I pulled the trigger for the Edelbrock 2650 item 15595 for the Hot Wheels. I took advantage of the cyber Monday 15% off and free shipping. It was a long process of deciding between the Magnuson and Edelbrock.
2018 Camaro 2SS M6 Hot Wheels,Edelbrock 2650, Hurst Short Throw Shifter. Production Number 90
1997 Camaro SS M6 LT4 tribute
tlk-1997 is offline   Reply With Quote
Old 12-04-2019, 06:51 AM   #2
laynlo15
Drives: 2022 Lt1 A10
Wish you could have went with Magnuson but congrats on your purchase as that's a good percentage off.
Old 12-04-2019, 07:15 AM   #3
Zack46
Zack46's Avatar
Congrats and welcome to the hot wheels club!
Zack46
Production Sequence Number 98
NEOCC Camaro Club Member
Old 12-04-2019, 09:02 PM   #4
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
You are going to love it!!!
2019 Crush A10
E-Force 2650
670WHP 615WTQ
All besides the 2650 is bone stock down to the air filter.
gotswap is offline   Reply With Quote
Old 12-04-2019, 09:38 PM   #5
laynlo15
The 2650s are pretty stellar.
Old 12-06-2019, 07:49 PM   #6
tlk-1997
tlk-1997's Avatar
Look what showed up today. This was a fast shipment from California to Florida. Shipped on Monday.
Old 12-07-2019, 08:10 AM   #7
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
Good lord that's a huge box they ship that in!.
Dysan911 is offline   Reply With Quote
Old 12-07-2019, 08:32 AM   #8
tlk-1997
tlk-1997's Avatar
It's the full kit.
Old 12-07-2019, 07:17 PM   #9
tlk-1997
tlk-1997's Avatar
I made great progress today. I got the disassembly compete and I am ready to start the assembly process. I heated the crank bolt and used my air impact and it came right out. I replaced the LT1 crank seal with a LS3. Thanks for the heads up EDFHOBBIES! The only concern I have is that the LT1 crank Seal seems it is install backwards. The flat side of the seal was facing inwards. I installed the LS3 seal flat side facing outwards. Hope this is correct. I see why the LT1 seal fails with higher boost. It super thin.
Old 12-08-2019, 07:37 AM   #10
laynlo15
These seal should have been installed at the factory. The LT1 seal as you can see if very flimsy. I pushed mine out last year and Ls3 is the fix. Just do it.
Old 12-08-2019, 09:59 AM   #11
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Choice choice replacing the seal. I would also advise installing a Metco valve cover breather that has the one way disk so it only vents to atmosphere under boost.
Old 12-08-2019, 08:36 PM   #12
tlk-1997
tlk-1997's Avatar
Day two.....Got the pulleys, belts and supercharger installed. I plan on using the GM CAI. Its a close fit with the supercharger belt drive but I think it will be OK. The instruction that came with the kit and the online one have some missing or misleading steps. The map sensor and brake booster hose is misleading. I hope to have everything done by next Sunday providing I get the tune from Edelbrock. I plan on running their tune for a few months.
Old 12-08-2019, 09:14 PM   #13
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Nice work! Looking good.
Old 12-09-2019, 05:36 AM   #14
wnta1ss
Drives: 2017 Camaro 1SS
Suggest checking with Edelbrock on what parts their tune was made with. The GM CAI needs an adjustment to the MAF calibration, so if they used a stock airbox when they developed their tune, it won't match your setup.
