![]() Drives: camaro Join Date: Feb 2014
The truth about Roto-Fab CAI
For a month off experiments:
Roto-Fab air intake will make the engine runs Rich. Notice that by many things: 1- Carbon buildup on the exhaust tips, Unburned fuel. 2- Much back firing when you release the acceleration pedal. Unburned fuel. 3- ODB II scanning: Fuel terms are much negative like ( - 13 % at (30% to 40%) throttle position, MAF rate 5,3 g/s at Idle ,cats temperature.. By removing the Aluminum bracket besides MAF sensor inside the roto-fab air intake every thing is changing. ## See the videos ## Please; Do your searching on your own. Don’t burn you beauty Camaro. See the videos: Note: I don’t have a video for ODB II (LTFT Nummbers) for Normal Roto-Fab with the Aluminum bracket inside, i did delete it after filming it, because i was very very upset, because i paid 700 $ for the Roto-Fab with shipping and taxes, and i did get very very bad numbers for fuel teams LTFT. it was -11 % and -13 %. Too rech. Every thing change by removing the aluminum bracket from inside it. LTFT now 0 % or 1 % or 2 % on throttle position 30% # It is just because MAF sensor get a little bet lower rating now, i remember it was 5,1 g/s or 5,3 g/s with the stock oem , and now with mooded R-F it’s 4,8 g/s The car runs like a beast now with rot-fab without aluminum bracket inside it. # You can adjust the numbers slightly by turning the filter inside the RF box. Please don’t burn your car if you live in a hot area. I live in cold area, almost all the year it’s under 10C/50F degrees. Goooood luck Sorry for my bad English. https://youtu.be/mtsfss-fn3U https://youtu.be/Wvsd-KyAwUc https://youtu.be/LMyhAj1lG8g Last edited by f.d; 12-04-2019 at 08:05 AM. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Oh, in on one.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 SS Join Date: May 2013
Um question...
Are you even tuned? If not your statements are invalid.
![]() Drives: 2017 SS 50th Join Date: Jun 2019
Do you need a tune with just the standard Rotofab dry filter system? Or is just for the big gulp and up? I would agree though if it's hecking with your car that much then you need to do a proper tune with it.
![]() ![]() Drives: 2002 z28, 2018 2ss 1LE Join Date: Sep 2012
#7 |
No thanks !!
In fact the car runs like a beast now. |
#8 |
Rotofab advertises no tune for the regular system. Big Gulp, tuning required.
'16 Camaro 1SS
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
If you know how these computers work, you don’t want positive ltfts.
Also if you don’t have a wideband how do you know what’s really going on?
#10 |
I can't find a photo which shows this "bracket" within the roto-fab. But it looks like vanes to direct airflow more than a "bracket" for support. Does it sit in front of the MAF? The stock MAF will be calibrated to sit in a certain spot in either laminar or turbulent flow. Any aftermarket setup will either have to match that or you will need a tune to compensate.
I agree with 6spd. I would think the best scenario would have both long and short term trims close to zero. Based on the video and emphasis on lack of exhaust soot, I would be worried about a lean situation with the positive long term fuel trims. |
#11 |
![]() ![]() ![]() Drives: 2016 Camaro SS Join Date: Sep 2018
#12 |
![]() Drives: gas powered Join Date: Jan 2019
My understanding is even the GM performance CAI needs to be "retuned" by the dealer?
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
I would think with that brace removed from inside the Intake tube the engine will burn a lot more fuel! I know when I removed the screen from the MAF on my LS1 1998 Camaro SS it ran like it had 50 more hp but it drank a lot of gas and I had to buy a new MAF due to the car burning so much I was filling it up every 3 days!
#14 |
Would like to see what rotofab has to say about this and what the purpose is of the bracket in the tube.
