![]() Drives: 2018 1SS 1LE Join Date: Dec 2017
1LE OEM wheel/tire combo rubs harness
Well folks, Took my wheels off today to clean them up after an aggressive track day @ Sebring... lookie lookie.. I gotta move that harness before it rubs thru! Any advice on how to take the liner out? Also, what does that harness run?
Thanks, TC
Tango Charlie
'18 1SS 1LE '68 SS LS2 '89 RS 'vert |
![]() ![]() Drives: 2002 z28, 2023 Zl1 Join Date: Sep 2012
Out of curiosity, what wheel is this ?
This is the driver's rear... It is a known problem with 305+ wide tires.
Tango Charlie
#4 | |
), should be easy to remove.The wiring harness is a section of the main body harness, see service manual excerpt below, you don't want that to rub through.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle Terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 11-23-2019 at 09:24 PM. |
#6 | |
TC
Tango Charlie
#7 |
Spotted the same issue after a recent track event - I thought about moving the harness if possible but if this is common why not get this done under warranty. Any thoughts?
#8 |
1LE drivers side rear wheel well harness rubs
Well thanks to arpad_M, I decided to move the harness myself. There are some YouTube videos and his service manual excerpt diagram helped me to accomplish this feat.
So, here we go! I circled the harness connection point that needs to be moved. Here you can see the actual harness point where it connects to the body. It is a simple push in- type zip tie holder so i just wiggled it out. I moved the harness back into the body, away from where the tire rubbed thru the wheel well liner and then zip tied it back against itself... there is a lot of slack so i am hoping this won't present another problem. I plan on checking it next weekend. Finally, I buttoned it all back up and felt around to see where the harness was now in relation to the previous spot. As you can see from the photo below, it is back away from where the tire rubbed thru the liner. The whole re-positioning drill took me 45 minutes.. that included jacking the car up, taking the liner out, taking the photos along the way, re-installing, and drinking a victory beer! I hope this write-up helps other 1LE/ZL1 owners with this problem. I do have a GM rep looking into why this is NOT a TSB for those of us with 20" wheels, since the car is made to be driven on track and could have this issue... I'll let you know what i find out. Cheers, TC
Tango Charlie
#9 |
![]() Drives: 2018 2SS Coupe A8 Join Date: Nov 2016
Great post Tango 1LE. Please do let us know what you learn from the GM rep.
#10 |
Nice post - seems like something I'll take care of while she hibernates.
#11 |
1LE Convert
Drives: 2018 ZLE Join Date: Apr 2017
I discovered the same issue yesterday. For me a zip tie is poking through the liner.
2016 Porsche 911 GTS (Racing Yellow)
2002 BMW Spec E46 race car (Lizard Green) Previous cars: - 2018 Camaro ZL1 1LE (Red Hot) - 2018 Miata RF GT (Machine Gray/Auburn) - 2017 Camaro 1SS 1LE (Summit White) - 2008 BMW 135i (Montego Blue) - 1996 BMW 328i (Arctic Silver) |
