Old 11-23-2019, 04:35 PM   #1
OVRKLL
Drives: 2017 1SS 1LE...makes me go YeeeHaw!
Header Bolts Anti-seize
Opps...Mods please delete my other post in the v6 thread, although this is relative to both.
Sorry if this question is one of those that has a given answer, but I've never did this before.
When installing Kooks Headers or headers in general, do you use Anti-seize on the bolts, or install it dry?
I have SS bolts from Summit, and Permatex Anti-seize with a 1,600 degrees F.
Or is there a special Anti-seize for headers to withstand higher temps?
Also, what about on the O2 Sensors?
Thank you!
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late!
OVRKLL is offline   Reply With Quote
Old 11-23-2019, 05:38 PM   #2
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
I didnt use any, kooks headers come with some locks so your bolts dont come undone, stage 8 I think. I didnt use any on the 02 sensors either but I cant confirm that is ok.
Old 11-23-2019, 10:38 PM   #3
OVRKLL
Did you use the bolt locks?
I'm thinking anti-seize just in case I ever need to remove the headers in the future, then again the heat might prove to be too much!
I will use them on my O2 sensors though, since I'll probably need to replace them sooner or later.
What did you torque the O2 sensors at?
Old 11-23-2019, 11:14 PM   #4
95 imp
Dumb Ass Deluxe
ALWAYS use anti-seize on header/exhaust man. bolts.
Old 11-24-2019, 02:16 AM   #5
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
GM tq Specs for dry and says not to.
Old 11-24-2019, 02:48 AM   #6
Booher
Booher's Avatar
I went to two finger torque spec haha, I dont actually know, just went off of feel. I wouldn't imagine too much. If you install the Locks before you button up your coolant tank it will be much easier.
Old 11-24-2019, 04:35 AM   #7
s346k
s346k's Avatar
Drives: like an old lady
been putting headers on various vehicles going on 20 years now. never used antiseize.
Old 11-24-2019, 12:00 PM   #8
OVRKLL
Thanks for the advice/suggestions!
Looks like this is a mixed topic of opinions, even on other forums.
I'll look into this further, maybe call a few shops and see what they say...or not say.
Old 11-24-2019, 12:04 PM   #9
6spdhyperblue
Drives: 2SS 1LE
There’s something dry on the factory threads.
Old 11-25-2019, 01:13 PM   #10
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
IMHO, definitely dry on the header bolts and yes for anti-seize on O2 sensors.
Ventmaster is offline   Reply With Quote
Old 11-25-2019, 05:26 PM   #11
CrazyCatGuy
I'm the cats pajamas baby
Drives: 2018 Camaro SS 1LE
I always go in dry. YMMV
CrazyCatGuy is offline   Reply With Quote
Old 11-25-2019, 07:27 PM   #12
RandRZL1
RandRZL1's Avatar
Drives: 2018 ZL1
Ok I usually stay outa these things but here goes, I have worked in exhaust shops every thing went together dry. Never had any major problems. My own shit? I put anti seize whenever I have dissimilar metals and or heat. Makes life much easier later on. Good luck!
RandRZL1 is offline   Reply With Quote
Old 11-25-2019, 07:31 PM   #13
JCunningham
Drives: 2017 2SS M6
well the only thing is if your going to put anti seize on them recheck the torque often. maybe go 25lbft wet
Old 11-25-2019, 07:42 PM   #14
OVRKLL
Yes that's what I've been gathering...the anti-seize does affect the torque value...and I don't want to break a bolt in them heads.
If I go in wet, I'm thinking around 20 + 180 degrees or so...maybe 22 + 90 depending on how it feels. Plus I'll use the locks.
The fun all starts tomorrow, since my company gave us all the rest of the week off...NICE!
